RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
problem with my hpi rs4
Old 10-26-2007, 06:37 PM
hpirs4evoguy
Default problem with my hpi rs4
my problem is i give the car some gas then turn everything on and start it then it revs really hi and im not even hitten the gas and shuts off wats the problem?
need help plz!!!!![:@]
Old 10-26-2007, 08:39 PM
cossack71
Default RE: problem with my hpi rs4
Turn all of your adjust screws back to factory setting, and retune it.
Could also be air leaks.
Old 10-26-2007, 09:38 PM
GYNAIKAS
GYNAIKAS's Avatar
Somehow, more air enters the carb than normal. Try to find out where the leak is. Maybe the carb opening is set too open at idle position. Another reason may be an air leak at the fuel lines or the fuel tank so it gets too lean instantly cause pressure in the fuel line drops and then stall (just like when you pinch the fuel line in order to stop the engine).
Old 10-27-2007, 08:40 AM
hpirs4evoguy
ok ill try
Old 10-27-2007, 10:02 AM
GYNAIKAS
GYNAIKAS's Avatar
First try what cossack71 said...readjust the needles. And if it doesn't work check for leaks as I mentioned above.
Old 10-27-2007, 10:26 AM
cossack71
And the air leak check includes the exhaust.
I usually change the exhaust gaskets after so many runs.
Old 10-27-2007, 06:02 PM
hpirs4evoguy
i did both but none of them worked. It still chokes and stops is there something else that could be wrong?
Old 10-27-2007, 06:05 PM
cossack71
New fuel lines and clean the tank.
And how old is your fuel?
The next phase after that is take the carb off, and rebuild it.
Old 10-27-2007, 06:44 PM
hpirs4evoguy
new fuel, brand fuel tank, new engine i dont think i should be haven this problem and fuel line works
Old 10-27-2007, 07:17 PM
cossack71
Ahh you left the part about new engine before.
Did the carb come with it, or did you reuse an older one?
How much of the break in have you done?
And one of the other questions I asked, how old is the fuel?
Old 10-27-2007, 07:43 PM
hpirs4evoguy
i have new fuel just bought it yesterday and carb came with engine its a hpit-15 and its properly broken in
Old 10-27-2007, 07:53 PM
rchabits
ORIGINAL: hpirs4evoguy
Get an inferno gt and sell that car.
Old 10-27-2007, 08:02 PM
hpirs4evoguy
i cant sell the car if its not worken properly and im only 13 im not made of money anywayz.back to my topic how do i fix it?
Old 10-27-2007, 10:14 PM
GYNAIKAS
GYNAIKAS's Avatar
ORIGINAL: rchabits
LOL...RS4 18ss is faster than the GT....and corners WAY better!
Old 10-27-2007, 10:39 PM
rchabits
ORIGINAL: GYNAIKAS
ORIGINAL: rchabits
Faster than a gt?hahaha last time i checked the evo ss could barely do 40 something. gt can do 65 out of the box.get it straight.
Old 10-28-2007, 08:33 AM
GYNAIKAS
GYNAIKAS's Avatar
LOL...are you sure? Cause it happens that I have driven them both...and I own the 18ss...not the EVO+. Go at youtube and watch the GT running and then watch a 18ss...it might change your mind. I thing you should get it straight...! Inferno GT barely does 45-50 when stock...and RS4 is 1:10 not 1:8...not to mention that on track GT doesn't stand a chance against sport 1:10 class!
Old 10-28-2007, 09:55 AM
hpirs4evoguy
can u guys get back on topic plz im still havin the problem here!
Old 10-28-2007, 10:11 AM
cossack71
"fatten" it up (open the HS screw) about 1/2 turn (factory set is 2 1/2, turn it 3) and see if it makes a difference.
Old 10-28-2007, 11:21 AM
GYNAIKAS
GYNAIKAS's Avatar
Did you check for leaks? I believe that problem may also come from a possibly bad glow-plug...
Old 10-28-2007, 11:42 AM
hpirs4evoguy
i checked for leaks already.and i have a brand new glow plug
Old 10-28-2007, 12:05 PM
GYNAIKAS
GYNAIKAS's Avatar
Hmmm...well then try the stock needle settings. Then COMPLETELY remove the pipe and the manifold and clear them with paper VERY good. Put it back together and then disassemble the carburator and clean it too (readjust the needles). Try a new glow plug (even if you think your glow plug is brand new it might have been damaged) and fire it up...! If it still doesnt work then disassemble every single engine part clean it with HPI inner engine cleaner fluid, dry the engine and assemble back carefully. MAKE SURE THAT IN ANY CASE YOUR FUEL IS BRAND NEW AND BETWEEN 16% AND 25%). Also make sure that your glow plug is medium one.
If there's still a problem try to experiment with different needle settings. If still there's a problem get a new one in order to relax again!!!
Old 10-28-2007, 01:34 PM
cossack71
There's another part I just thought of.
Disconnect your throttle linkage, and see if it does the same thing.
You might have a servo that went wacky.
Old 10-28-2007, 02:19 PM
GYNAIKAS
GYNAIKAS's Avatar
[X(] OMG!!! I hope he has thought of it and he didn't start disasembling the engine!!! THAT's THE FIRST THING WE CHECK: is that a mechanical or an electrical problem of the throtle!!!!???!!!???
Old 10-28-2007, 02:55 PM
cossack71
Very true. I got caught like that once before when I changed radios.
It worked, but it opened the throttle about 2/3 way when I powered it on, and I didn't know it.
It started, dogged for a second while it was burning off the excess fuel, and then went blasting across the garage into the wall.
I always start them on a stand now.
Old 10-28-2007, 03:29 PM
hpirs4evoguy
um i did wat u said and disconnected it and now its feeding the engine gas but then i reconnected it and now it going fast and smoking up a storm and when i hit the throttle it goes slower and shuts off ?
