i need some help here
NJ
RE: i need some help here
There are a couple of options. Slot it, easy out, or just drill the head off the screw and with the little bit of screw sticking out after the head is popped off, grab onto it with needle nose visegrips and crank it out. I recently needed to drill off the screw heads on my engine, the wierd size flathead screws on Nova base engines are annoying. The only screwdriver i could get that would fit right twisted the tip off, because the screws were so tight. Even heated it up before trying, no luck. Drilled the heads off and no problem. Ordered hex style screws for it, and now its all good. The best thing to prevent stripped screws is to use good hardware, 12.9 grade screws, and to have a good wrench set.
thanks for the advice but i got the screw out i used a hammer and a screwdriver and just put the screwdriver on the screw and hit it with a hammer a couple of times
ORIGINAL: ferrarimk13
which kind of screw? if its a hex, itll be very hard, especially if its countersunk, if its phillips, just use a flat head.
