problem 2
problem 2
hi
i try today the new exhaust and when i try to adjust the settings, the engine just stops and it locks.i remove the spark and try to remove the fuel but wheels spin when i pull the starter!! gearbox problem? what the hell?#$%%$%%
can someone help me?
1 Post
RE: problem 2
Clutch, not gearbox
You'll first have to remove the engine from the car, and then get at the clutch itself by removing the screw securing the clutch bell onto the crankshaft.
RE: problem 2
please go at the start of this thread and see the new pictures that i add..can we make a conclution to what happened? and what is needed?
thanks
thanks
RE: problem 2
WOW your clutch shoes are destroyed! The good thing is that you don't have to spend a lot cause clutch shoes are cheap. I'd suggest you to upgrade to a more durable set of clutch shoes.
1 Post
RE: problem 2
Jeez those clutch shoes have had it! If i were you i'd order a couple of sets of replacement shoes from the manufacturer (as GYNAIKAS says, they're cheap and it'll allow you to run the car again) and in the meantime look for a better clutch. A decent 3-shoe clutch would help, but you'd need a new 3-pin flywheel to go with it.
NY
RE: problem 2
yeah, only stocks look like they will fit, you might want to get an MIP clutch or something, with aluminum shoes, itll be expensive but worth it. I never saw shoes like that before.
RE: problem 2
Me neither! But I think that now that he knows what's going on it would be hard to destroy them again. So I'd say buy the original stock clutch shoes.
RE: problem 2
problem fixed, shoe replaced easily and the car is ready for the adjustments,
stouris i am waiting for you when you have time to meet
RE: problem 2
problem solved
after gynaikas explanations i manage to adjust the idle and have a good setup on the engine, now car is stable when i want to,
thanks gynaikas and stouris , i have learned a lot in our conversation,
another happy new is that the new exhaust i install on the engine looks and works fine, now i have more smoke coming out from it,
with the same adjustments for fuel/air, i hope and power..i will run it tomorrow and let u know
RE: problem 2
Hey, don't forget about me Looks like you got a conversation there. Was it the time you send me the MSN invite too? Too bad, i wanted to talk with you guys and got some knowledge too I must have been working on the Evolva that time.
RE: problem 2
Yes!!! I have osiris, cyptiot boy, winner and pollapellos MSN. Why don't you all give your MSN to the others so that we can all sometime chat all together???
