more power at the rear..
hello guys,
yesterday i run the car for 2 hours without problem, but when i fuel the car to run it for the last time, it appears to have more power to the rear tyres> spins the rears easy and car is difficult to drive.
i check the front wheels, all the parts that give the power to the front, but nothing looks wrong..
When i lift the car on the air and press the gas, all 4 wheels rotate normally,
maybe something is wrong on the front and it loses power? it looks to have move on the front but is not like before...
RE: more power at the rear..
Check the belt and/or gear system again. You might be wrong with that you telling It uses differentials your car or standard belt and gear system?
differentials,
greek: file exo tin apopse oti mpori na faithike to mprostino granatzi pou vriskete mesa sto differential, prin 1 vdomada allaksa to piso..isos na xanei ligo kai to mprosta tora.....de 3ero tha to ksiloso otan vro ora kai tha do
Does your car have center differential? If yes then for on road use you should block it. Test the car. Hit the brake and try to roll the car with your hand. If all the wheels are blocked then everything is ok and you should just setup your rear suspenssion better. If the front gears roll and the rear are blocked then check for any loose screws that hold the drivetrain cups.
ORIGINAL: Spetz
I didn't understand which part of the diff is the "granatzi"?
And how come you needed to change the rear one?
yes i am too guesing its a diff, i had the same problem, when my front diff was tost the rear was spinning, making it impossible to drive
when i hit the breaks it stops immidiately(all wheels) , maybe it just slips a little inside of the differential, i will check it and let u know
I make the car some pieces to clean it mostly and to repair the damage..
see what i found!! a piece of plastic is broken
i must find another to replace it...i dont think i will find one in my LHS, but i will ask. maybe ebay is my only solution...
I found out that the front differential has a problem and i will replace one of the internal differential gear..
i check some spare parts that i bought some weeks ago from my LHS, on the bag is written SMARTECH!!! i hope that they have this part, tomorrow afternoon i will visit them ))
Well visit them. If they sold the car to you they are forced by the company to provide parts support! If you can't find the part then search at e-bay. It's easier than you think.
BTW I remember you asking about swaybars and if you have one etc a while back, and from the pic you posted you can see the swaybar on your car
It's weird though from the pic it doesn't seem to be connected to your diff case which means it wouldn't do anything
Double check if it's connected properly (swaybar)
