Rs4 centax clutch who makes them?
WV
I have a rs4 evo 3 and want to put a centax clutch on it and seen hotbodies sells a centax clutch but they say you need there motor mount and I can find that in stock anywhere.Thanks
RE: Rs4 centax clutch who makes them?
Motor mount? You mean flywheel. Well I believe that most centax type flywheels will fit but It would be better if you did a bit more research on the subject. By the way why a centax clutch? If you install the heavy duty HPI one you'll be more than fine. I've modified the engine and I still use the stock clutch! Works more than perfect even for my racing needs.
hmmm. I was thinking about a centax clutch the other day , but the my honest opinion would be to go with the hpi racing clutch so i would say gynaikas is right and i would say that in most cases a centax clutch is more used in racing, that is what i think.
