please help with kyosho gt 2
what are the settings for the needles ill get it to start but then it just dies right away when eve it is given any throttle so whats the problem here?
RE: please help with kyosho gt 2
not the glowplug just replaced it so well c its starts but dies when ever i give it throttle or hit the brakes im taking it in tommorow
PA
Is it new? If it's the same engine that in the GT the high speed needle book setting is 3 turns out. I found this to be way too rich even for break-in. The low speed is set .5mm below flush. That setting is very touchy because your moving the seat, not the needle. Sounds like yours may be too rich. Make sure your throttle opening is about 1mm with the brake applied(looking down the carb throat).In other words make sure the throttle valve is against the throttle needle and not being held there by the servo.
