Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
Thanks, because for my next project i am going to be putting a .21 in a 4-tec and running the 1\8th scale wheels, and i want something to hide it all from plain sight
You can't hide anything with a 235mm body on a 4-tec. I've had the big wheel/tires on a 4-tec and anytime you use a belt driven system car, you cannot sit the wheels in enuff to have the body cover the tires. What I did do though was cut down some of the wide rear tires and then the body fit over the car but then the stock plastic outdrives will crack and break. I replaced them too many times and just dumped that project all-together. Here's a few pics of mine. Oh and I had a RB Xenon R .21 in the car too. It was a animal in a cheap car that handled for little to nothing.
My goal with the 4-tec is to not only take it to 100mph bacuse people say it wont do it, but to also make my first trip to 100mph
ORIGINAL: bigwill5686
I have already had it to 75 with the 3.3 gearing changes and the stock super nitro foams. It took forever with the 3.3 to get there though, so i am thinking a high powered .21 will help in the process
#31
Well i guess its time for me to chime in with my .21 1/10 scale monster, i just took some pics and the car is a little dirty but it is a weekly driver!! as you can see we do things a little diffrent as far as set up's and wheels
BTW motor is a Ninja 21 wtih a diffrent head, and novarossi 9886 pipe custom ported motor and running on 60% nitro boat fuel
#32
FL
Wow, you must have to be very smooth to keep that car going in straight line with those pizza cutter looking tires on it.
#33
Miami, whatever the case may be bro. That is what I like to see, different combos. Now how much more power is there to be had using the 60% boat fuel? Noticable or not?
#34
ORIGINAL: Brent Davis
On 60% nitro there isnt MUCH a diffrence between, there is only a little added tourque over a modded motor on 30% which rounds out to about 2 extra teeth on the clutch bell which is only about a 5 MPH diffrence
same motor same set up BOTH modded one on 30% the other on 60% the 60% motor will be a little faster becuase of the fact you can add motor teeth to the bell but like always a little bit counts
to run 60% the motor has to be completly timed diffrently and motor SPECIFALLY for 60% nitro and thats where my homeboy octavio comes in to play he's bein doing it for years and leaves everything to perfection, another added plus about running boat fuel is the fact the boat fuel has more oil and seeing as i driveing my racer 2 on a street about 3,000 feet long and actually use about 1,500-2,000 feet i need to keep the car screaming that long with out risking it running out of oil content
even tho 60% nitro sounds like alot it also has 20% oil in it so it protects the motor alot and keeps everything lubbed and working great
BTW takeing a good look at my car HOLY HELL its dirty, ill tear it down in the next few days and clean everything the flash on the camera really brings out the dirt!
#35
Thanks.
What Futaba reciever is that? I am going to get rid of my Spektrum junk and right now I am using the stock OFNA TX/RX combo and that is working just fine. The spektrum is waaaaay too unpredictable and has caused me to loose a car already.
#36
Here is mine i did this about 3 years ago' super nitro w/32 ofna
carbon fiber chassis 5mm,the biggest gears i could find.a lot of folks
said it couldn't be done,but i did it and trust me the thing would HOLLLLA!
i also have those wolfpack wheel adapters.
#37
Dayyyuumm. You put that big RTR engine in there and I guess with all that TQ it does move out very well. I love it when ppl tell you that it won't work and all that but you proved them wrong.....he,he,he. Does it still run good on top end with that motor? you get that engine ported or put a Picco P3 in there and WATCH OUT!
I really enjoy seeing what everyone else does and I also get ideas as well.
thanks to all that have shared information and pics.
#39
thanks fellows,with that big 32 man words just can't describe it,i can truly say and i kid u not!
when that thang run past you u can actually see the dust twirling off the ground. when the
car is on topend it really-really scares me thats just to fast.
#40
ok i know that this 1 dosen't have to much bearing on this thread but
it does say in the title .21 or larger engines.
this is the twin titan when i get done with this truck
there won't be .26's install in the belly,this 1 is gonna
wakeup the DEVIL!
wakeup the DEVIL!
#41
Where did you get that CF chassis from?!?!?!!?
Brent im useing the futaba F143 reciver with no problems in fact ive bein useing that reciver for over 4 or 5 years with no issues, i too tryed spektrum and its the biggest POS on earth, if you in the market for a new radio go with the FASST system its 2.4 and the system is bad ass IVE NEVER have a glitch EVER on my cars useing the FASST system little by little im moveing everything over to fast, and the range........THE RANGE IS CRAZY ON THE FASST the spektrum range SUCKS
#42
ORIGINAL: MiamizFinest
#43
OMG, I thought it was me or just interference from my 'hood. I agree that the Spektrum chit is just that........JUNK! I totally destroyed a FAST CD3 that was about 2 months old with a nasty Kangaroo that the head got damaged in the crash because the Spektrum lost radio contact and the built in failsafe didn't work. How much for a FASST with RX'ers?
Here's what that junk did. Every since I am using the stock 27MHz stuff, no more issues what-so-ever.
#44
FL
hell yeah, spectrum sucks, FAST is the only way, especially if you have an expensive car.................
#45
ORIGINAL: Miami Jato
LOL, I would think that it wouldn't matter if you have even an inexpensive car. The damn Spektrum is supposed to be the chit but it is definately junk from what I have seen lately.
#46
Yeah every i knew told me to get spektrum,blah blah blah, biggest waste of money in rc in my opinion
#47
Yup. I only trust my cars to the Futaba radios. Now Im using the 3PK with the Fasst module. I trust this system all day. To put it in prespective, I can take my 1/5 scale sportline with a white body in the day time, as far as I can see it and still have total control of it. I tested this a few times for high speed run and I take it so far that I cant even tell which way they car is facing. Needless to say, that many times I've had to walk to it because when I think its facing foreward and pull the throttle, it just gets further away. If I had to guess, I'd say the fasst has more than a 1/4 mile range. Thats easily 1300 feet or more than 4 football fields.
#48
ORIGINAL: Got_to_100_now_die_hatin
#49
The cf chassis was cut out by me using
a handheld router. A lot of tyme went into cutting
the cf and a boxcar load of carbide bits,the cf was
5mm thick.
5mm thick.
