Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
#2001
RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
Guys you have too look at the weight that each engine wights.
19tz weight is 12.1oz devide by 2.4hp = 5.04oz per hp
18tz weight is 7.8oz devide by 2.28hp = 3.42oz per hp
I think I did it right, if im right then the 18tz mod is better.
But then you have to look at the rpm's too.
#2002
FL
yea it do thats why i have 5 novarossi's to 1 os i dont mind spending i got a few modded mills too
#2003
FL
no nitro i dont we kinda like the 3.3 around here for small blocks some got the 18 tz but we found a rb mod 3.3 is kinda hard to beat i got mine modded davis hd conecting rod and ceramic bearings in it it was funny the first time i pulled it out on them thay didnt think it was a 3.3
#2005
nitrohead, you already have a bad .18 TZ on the V1RRR. What's the problem mang? Hey did you ever get with that guy to make those shafts for you?
I too LOVE the RBmodded 3.3 engines. Rick is in the works of making billet pistons for the engine now to go along with his billet rod. My 3.3 engine was just as quick/fast as my friends modified .18 TZ to the point of I beat him 3 out of 3 top end races......we swapped controllers and he beat me letting us know that the modified 3.3 is a beast. I will say that Rick turns my drag modified 3.3 engines into a 5 port sleeve.
Here's a video of one of my RB mods 3.3 engines in a CD3.
http://www.youtube.com/watch?v=1u7gtgyvR5c
Here's the new billet rods that are made for the 3.3 engines by Rick Brake of RBmods.
Here's some crank stuff that he does
Here's the dual head button installed along with a TM523 8mm carburetor.
Here's the aluminum crank for drag modified 3.3's that are serious.[X(]
Pic of a billet rod/piston combo compared to a stock rod/piston
another billet piston shot.
#2006
ORIGINAL: Brent Davis
#2007
FL
its all good nitro a chevys a dang chevy but hay youll be rite in no time we all know that
and yea brent i seen all the stuff rick workin on i was gona try the crank but m thnn its not for me but i am gonna get the turbo coolin head from not the twin tho i think my next 3.3 i send him i might go with the piston this time too
and the carb i got a few lrp .30's and i seen if i pull off the gray sleeve around the carb it drops rite in i may try it one of these days
#2010
ORIGINAL: nastyboys727
The .18 TZ is without a doubt a great engine but for OS to share the same rod out of the .21 TM with the .18 TZ is the problem. The rod will let go under very stressful runs as I've seen this a few times.
#2011
A 9mm carb Brent?? Off the chart man, off the chart!! With this engine your cars are going to be hitting 100mph in 132 ft!!
#2013
NB it is just that I have never put anything bigger than a 8mm carb on any of my engines. But I am not into 1/10 scale like I use to be. Still working on my 1/5 scale NB.
#2014
Hey Guys, its been a while. How is everybody doing? I have a question, what do you guys think of a RB tm523 engine? Thank you........ Brent that modfied 3.3 engine looks like a monster
#2015
ORIGINAL: solo0610
I have already tried and used a RB TM523 engine in one of my CD3 cars and it is nowhere near as fun as a modded 3.3 let alone a .21 BB. It was designed by RB for the REVO and T-Maxx type trucks so the proting structure isn't top end friendly.
#2016
Ohh okay thanks Brent ill leave that on my revo then. Im trying find something to put on my ct5 right now. i was think of a modded os 18tz lease money really isnt in my option from rebuildng my revo.
#2018
As anybody ever order from Vantage Racing? how long do they usually take to ship something out and where are they located?
#2019
ORIGINAL: solo0610
#2020
Thanks Fuel Crazy, did you get a shipping number so you track track your package... I just recieved an email with an receipt of my purshase and thats all
#2021
So...this past week, i've been tinkering with my HPI rs4 evo....i wanted to put a big block in it....so...after looking on my local craigslist for a big block motor, i came across a trx 3.3 for sale for 50 bucks.....i ended up getting the motor for 25 bucks...its in great condition..after about 100 bucks more..i finally got it all installed in my rs4...thought i'd share a pic of it below...
On another note...i've been looking for foam tires that are wider then the 30mm contacts i got on the rear now...does anyone know where i can find wider ones that fit a standard 12mm hex??
Heres a kinda crappy pic of the car now...iam going to get some video of it in action....
Maybe i'll have rick modify this 3.3...
#2022
you can get the GPR 44mm tires from Kamikaze. If you look back a couple pages, you'll see someone with them on another car.
http://kamikazetoysandhobbies.com/products.php?cat=9
#2024
If you are asking me, i have no ties with Kamikaze. Hopefully they have them in stock again, cause they are the only place ive found with them, and im looking to get a set myself soon.
#2025
What do you guy think about my Revo? Its a project I been working on, im not done yet but this is what I have
Rb Concept tm523
Vantage Racing Carbon Fiber Chassis Extended Version
Vantage Racing RE0003 Center Shaft
Ofna Racing Fuel Tank 1/7 Scale
Tekno RC Rx/Battery Box/Fuel Tank Conversion Revo
Traxxas Servo Mount Throttle
RPM Tubular Front Bumper Blue
RPM Tubular Rear Bumper Blue Revo
Traxxas Aluminum Pushrod Red
Traxxas Wing Mount Revo
Traxxas Wing White Revo
RD Logics Aluminum Arms Set (Titanium)
Traxxas Drive Shaft Revo (Steel)
RD Logics Steering Block
RD Logics 23mm Aluminum Wheel Hub
Tekno RC Sway Bar Kit
Integy High Flow Air Filter for Revo
and etc.....
Rb Concept tm523
and etc.....
