Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
#2227
NY
RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
I finished the one speed today, I opted to use an old rs4 chassis instead of the super nitro RS4 (body choices etc...) we shall see how it handles soon..
Waiting for the exhaust.
#2229
Your WAY under geared my friend!!! Wassup with the wheels?! ull be better running regular off the shelf foams......trust me
#2230
NY
ORIGINAL: Car-Boy
Does the body still fit?
ORIGINAL: MiamizFinest
The wheels/tires are fine, I've run them on my other car, a super nitro that went 96.4 with those wheels.
I may go to regular 65mm's because it's a little too boggy. (overgeared)
#2231
Does anyone know where to get the low profile foam tires carbon fiber rims that Nic Case used on his world breaking record holding car?
#2232
if im running a 30 pinion in a 36 spur gear with a rb 21 engine that been mod what you think my top speed will be
#2233
#2239
NY
If you are running on the stock racer 2 pulley setup 18/39 your cars drive ratio is 2.166 so you would need to pull around 35,000 rpm to hit 100mph assuming your tires are standard 65mm with your current 30/36 gearing.
#2242
This is a car i built from spare parts i had lying around.I built this car well over 10yrs ago and sold it back in 05 0r 06.It went pretty well for what it was,mostly just spun the crap out of the rear tires through the gears till it hooked up and took off.Built from assoicated,tamiya,kyosho and hpi oh and yokomo parts.Oh and marui.LOL
#2243
ORIGINAL: roadrunner ss
how can i upgrade my pulleys on my hpi racer 2
#2246
ORIGINAL: Car-Boy
#2247
I don't think he made them himself. He mentioned the company on the video. I looked it up but they don't sell them there.
