OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
#251
PA
You have a servo saver on yours? I took off the servos and the whole radio setup.. I have a different radio setup.. I have those X type tops for my servo arms. Works like a charm for my brake and throttle. I have a different arm on my brake also. I have an 4-tec arm on it. Blah! But yeah, the idle needle holds back the throttle from being completely closed. I used to have the problem that once I press on the brake the car would want to shut off. So I fixed that sorta
Jack
Jack
#254
is there a way i can set up the car so i can get rid of the reciever tray?? i hate that thing. i want to make minimal adjustments.
#255
Ok ...its not the idle set screw,thats fine.....the upper and lower stock arm keep moving apart and not springing back.I'll get it,just wondering if alot of people have changed that part.
Getting rid of the reciever tray?Are you talkin about the lil black box that sticks up?Would a new upper deck work?
#256
Try taking out the metal ring and squeezing it together more with a pair of pliers.I didn't have this problem on my SS but I did on my Savage21 and it fixed it.If it's the servo itself thats not going back to center try adjusting your trims and see if that works.
#257
Ahhhhhh! cool,that'll probably work....I had a problem with it the last time I ran it before yesterday but I guess I forgot.Thanks man.I'll try to check that today.
#259
About that fuel tank.....IT SUCKS.Now I see why someone wanted to get rid of that primer(maybe it was Rex) and now I do too.I was preparing to run the car yesterday and I was pumpin that lil thing forever before fuel got to the carb.I was wondering why the tank is covered with fuel after every run...now I know its that lil primer leaking all over.If I had a primerless tank and a pull start....how would I get the fuel to the carb at first?
#260
i aint sure but my mate had a traxas? and it had a primer less tank and a ez start, he hold his finger over the exhaust pipe and then it started?
aint to show though.
#261
without the primer just plug the stinger and pull the cord a few times, not hard, just enough to move the crankshaft.
#262
Yeah all you gotta do is put your finger over the stinger and yank the pullstart a few times.I haven't figured out how to take the primer out of mine just yet but i'm still working on it.The primer isn't like the one on my Savage21.This on goes all the way to the bottom of the tank and it looks like it won't come out with some problems.If they got it in there i'm sure I can figure out how to take it out.
#263
What I do instead of playing with the primer is pull the pressure line off the exhaust and blow into it until I see the fuel reach the carb. That gives me enough fuel to start within three pulls. I read somewhere that someone took off the primer and stuck a screw in the hole with some silicone sealant. It seem to work for them. I have yet to try it..
#266
rs4 pics at my new web site look at my pull start after the frist pull it is the pic of the week and if you dont see the pics tell me im trying to fix it but i cant find out why or how it is doing it as of right now so go here and tell me what you think i know it need some work but im trying
http://home.insightbb.com/~veryhot124/cmcracing.html
thank you
thank you
#268
well where's the pics man?I wanna see that crazy exhaust you have.....how well does it work and what difference did you notice?I never ran mine with it on.
#272
Heatsinks,or "fins" have to have air moving across them to work....do your engine mounts get all that much air rushing by?They'd look cool but seem about useless to my hop up happy self.
#274
If you really think about it the chassis on the Rs4 is aluminum and transfers heat from the heatsink.The stock heatsink is cast aluminum so it doesn't tranfer the heat as well as a forged or billet aluminum heatsink will.It's like with the expensive heads you can buy.The cheap ones are made of the brittle cast stuff that don't cool as good and will break on impact.The good heads will bend long before they break because there made of the forged or billet aluminum and they cool better too.
#275
Re: oh,its beautiful
Originally posted by GALAXY
I just got my box of parts yesterday and thought I'd get a pic...I'll get better ones later and report back as to how well they go on.
Lots of alloy stuff.Whats in that big bag on the left??
