OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
#4526
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
this looks like a pretty good deal. http://www.ultimaterc.com/forums/showthread.php?t=94305
#4527
CA
It comes with good upgrades. It is a definite must buy. I would buy it but I have enough rc cars already. I have bought single engines that cost more than that whole car. My suggestion is for you to get it asap before it is gone.
#4530
ORIGINAL: Red7fifty
RX battery charging......More photos later.......
How about some more pictures of yours?
#4531
MA
ORIGINAL: Red7fifty
#4532
hi guys,
what kind of servo is good for throttle?? fast or torque? Been thinking of changing as for now im using normal servo....
thanks...
thanks...
#4536
My Feedback: (73)
ID
Thanks GYNAIKAS and Fieroboy.
Fieroboy, if that body has a lot of flex at the windshield, you might consider adding a 5th body post for support in that area. Serpent does that with their 720 car. You'll have to modify it yourself, but would be worth the effort.
#4538
My Feedback: (73)
ID
(Hot Bodies F-50 GT1......circa 1996, long discontined)
HPI S7R with Vantage Carbon Fiber wing.
HB 4mm milled chassis
HB Carbon deck
HB CVD F,R,Center
Stock 12SS engine (have HPI 12RSC, a NovaRossi with HPI badge, waiting to go in, but stock engine will not wear out!)
GPM Carbon brake disk
GPM light flywheel
S9350 Digital Steering
BLS451 Brushless throttle
K&N
HPI carbon shock towers
HPI F/R sway bars (note, these are not very effective, too much slop in the system to work properly)
RD Logics Turbo II pipe........(was running a cheap Duratrax pipe previously, and that had great top end, Tower for $20 bucks, FYI)
Car has a tendency to be heavy on the right side (engine side of chassis is heavier), handling can be improved by shifting battery weight as far left as you can get it.
HB Carbon deck
HB CVD F,R,Center
GPM light flywheel
K&N
#4539
nice car!, sway bars are rubbish?
can you compare the gpm flywheel and brake with the stock
thanks
thanks
#4540
so the duratax pipe is better for topspeed?
but which one is durable and overall better
thanks
link please
thanks
link please
#4541
My Feedback: (73)
ID
HPI swaybars, just add weight to the car....they do nothing to limit body roll....even without shocks on, you move one arm all the way up, the other side doesn't even move!
Light flywheel, good item to buy. Holes are vented at an angle, so it helps cool the cluch too, stock cast flywheel ia heavy, light flywheel engine spools up much faster.
Any fiber brake will upgrade the stock plastic one.
#4543
My Feedback: (73)
ID
Both pipe are good, The Duratrax is half the price. Also depends on which RD pipe you pick, and which Duratrax pipe you pick. Your tuning, fuel, plug (running O.S. A5) Redalert 20%, and running area. The cheaper Duratrax pipe you can experiment with changing the tunning lenth, by cutting the stock header and adjusting the length of the header for more bottom end, etc. Can't do that with the RD with sping coupler.
The Duratrax model I bought, I no longer see on the website, might be discontinued. My friend has the Streetforce GP pipe, decent results with that pipe ($18) as well as the Associated NTC3 pipe, stock is "torque tuned" and works very well....also available in "RPM tuned" but haven't tried it.
MY RD pipe is the Turbo II outlaw (larger exhaust stinger) and works very well, but cost twice as much.
#4544
MA
ORIGINAL: Red7fifty
#4545
WOW!!! First of all...sway bars don't lift the other side...they reduce its tension. So they work and they're not crap. And pipe always has to be chosen wisely. What engine do you use? What are your power needs and at what rpm range? And "hello" you can't just recomend a pipe cause you like it! If I recomend my pipe for a car with a .15 engine the result will be crap.
#4546
MA
Hey G...I got a ? for ya. Does anyone make h.duty d.bones like the MT2 for the RS4 Evo? I Know the bone to the rear diff fits from an MT2, because I'm using one. I don't beat on my car but I know that if I did they will snap.
#4547
CA
Hey Fieroboy, I don't know about heavy duty dog bones but you can get this. It's cheap and it works fine. It is a complete set for the rs4. I personally ran my rc car with a big block engine in it and I used heavy duty diff cups for my drivetrain with stock dog bones. It works fine until recently when I hit something and one of them snap. other than that, it works fine.
URL:
http://cgi.ebay.com/HPI-Nitro-RS4-3-...ayphotohosting
URL:
#4548
ORIGINAL: Fieroboy
Not really...if you want domething more durable and lighter get the original HPI CVDs.
#4550
Just couldn't resist the temptation,
I ordered some alloy parts for the rs4 Evo3.
I just broke-in the new T3.0 engine and it drives like....
Can't wait to recieve the parts.
[ul][*] GPM ALLOY RADIO PLATE WITH POST NRS3014 fits HPI RS4 3
GPM ALLOY REAR BODY POST SET NRS3201R fits HPI RS4 3
GPM ALLOY REAR SHOCK MT TOWER NRS3030 fits HPI RS4 3
GPM F C HUB ( /w BALL BEARING) NRS3020 fits HPI RS4 3
GPM STEEL F&R UNIVERSAL SHAFT SET NRS-C fits HPI RS4 3
GPM UPPER BUMPER & POST SET NRS3220 fits HPI RS4 3
GPM ALLOY MAIN CHASSIS NRS3016 3MM fits HPI RS4 3
GPM ALLOY F SHOCK MOUNT TOWER NRS3028 fits HPI RS4 3
GPM ALLOY FRONT MOUNT PLATE NRS3015 fits HPI RS4 3
GPM ALLOY REAR BODY MOUNT NRS3032 fits HPI RS4 3
GPM CENTER GEAR BOX SIDE MT NRS3040 fits HPI RS4 3
GPM STEEL MAIN UNIVERSAL SHAFT NRS3037S fits HPI RS4 3
GPM ALLOY F/R GEAR BOX NMT2012 fits HPI MT2 RS4 3
GPM CENTER GEAR BOX MT SET NMT2038 fits HPI MT2 RS4 3
GPM STEEL ALLOY HANDLE SET NRS3112 fits HPI RS4 3
[/ul]
If I'm not mistaken, our RS4 Evo3 is now complete aluminium, can't wait to see how she handles....
The car: (last photo's with stock engine)
My other beauties:
[/ul]
My other beauties:
