nitro mini rs4
LA
nitro mini rs4
well i had an issue with these hong kong parts for my mini , i currently redone the whole front end in aluminum, when i put on the the fixed front turn buckles i had a major camber issue i went through a 40 dollar set of tires in about 5 tanks , so i cut and made my own adjustable buckles , now i have an issue with the dogbones falling out , i put some rubber washers in my cups and still they keep poping out , does anyone know of a set of cvd's i can replace these with from a difrent model , beings they never made a set for this little bugger .
RE: nitro mini rs4
Ahh, the HPi nitro mini! Still one of my favorite cars.
HPi themselves made universals for that car, and depending on whether or not you feel like ordering from over seas, they are still available from here [link=http://www.rcmart.com/catalog/for-hpi-hpi-rs4-mini-c-595_737_865.html]http://www.rcmart.com/catalog/for-hpi-hpi-rs4-mini-c-595_737_865.html[/link]
I've bought stuff from RC Mart numerous times without issues. In fact thats were I bought my set of universals from.
Also, MIP made CVD's for these vehicles, they are hard to find now but they do pop up on Ebay from time to time (if I don't beat you too them, lol) Really the only parts you need are the actual short bones for the mini, the axle pieces are fom the standard RS4 and the pins and sleeves are all the same for 1/10 scale, I have seen just the bones for sale on ebay as well.
Aside from that I don't know of any other ones that fit.
LA
RE: nitro mini rs4
well im just worried about them cvd's being the same length as the bones , it calls for 30 mm bones , i guess im hoping that someone will read this and know their bone size , id guess i need a 32 mm , i`ll probablly end up trying to put rear cups in the front and just grind them down till they clear the c hubs ,
RE: nitro mini rs4
The problem with dogbones is that they are free to float in between the diff cup and the axle cup, and more than likely you are having issues with the front ones falling out when you turn, correct?
With CVDS you have a fixed point that doesn't telescope. so all the float comes from the other side of the bone, and that is the side that doesn't see the extreme angles from turing your wheels. So they pretty much eliminate the chance of the bone falling out. I hope that makes some sense, but I'm pretty sure CVD's or universals would solve your problem.
Does anybody know where I can get a body shell that will fit the HPI MINI RS4 nitro. Bought one from a car boot last w/e but at a wheel base of 225 I can't find a shell anywhere.
Help
Help
