clutch problems
clutch problems
Hi im from (PUT ANOTHER SHRIMP ON THE BARBY & THE DINGO STOLE MY BABY) Australia
ive got an a car off seben racing and the clutch spring has broke is there any upgrades you can do
cheers
cheers
RE: clutch problems
As far as upgrades go (I'm from Melb), the best "idea" is to get an adjustable clutch, I know there is one made by Fioroni called the Vario or something like that. It should fit exactly where the shoes would go, but you can adjust it like a centax clutch.
Either that, or just buy a bunch of springs that fit, and replace them when you need it. Or you can just fix up the spring where it broke and she's good as gold once again.
RE: clutch problems
ORIGINAL: D.DJ
RE: clutch problems
yup ,fioroni is an entire flywheel ,clutches and adjuster cam rolled into one, and are about 60$.
actually here is a link to amain that has a bunch of racing clutches.
http://www.amainhobbies.com/index.ph...arket-Clutches
