HOW TO USE A SLIDE CARB ON RS4 3 .18 OSV
QC, CANADA
I have a .18 os installed on my rs4 3 ,
how can i use the slide carb version..... of the .18 os with this car can't seem to find a way with every servo horns i have it's a total pain in the butt to be postpone like this
RE: HOW TO USE A SLIDE CARB ON RS4 3 .18 OSV
I would try to turn the carb to a position where it would allow the servo to open and close it, otherwise I would then try to make something to get it to work. Im not to sure on the RS4, but I have had that problem before.
QC, CANADA
can anyone teach me? this is the first time doing such a thing , ill be good to teach others at the track later : )
Its not so much turning the ball on the carb, its actually rotating the whole carb ON the engine around so its in a position better for the throttle servo. Sometimes it can be done just as easy as that, sometimes you have to make something or do something to make it work.
