Engine suggestions for a HPI nitro rs4 2 with 2 speed trans
I currently am looking at a os 18 tz and traxxas 3.3. I want to know if something like this would fit in that chassis?
any other suggestions on what engine would be ideal for great open lot mobbing would be greatly appreciated. want to make this car really shine and just be a true blast from the past. |
1 Attachment(s)
Originally Posted by JacobR
(Post 11954885)
any other suggestions on what engine would be ideal for great open lot mobbing would be greatly appreciated. want to make this car really shine and just be a true blast from the past. I bought the Ofna 18 for one of my Ld3's,it runs pretty good,but know where near the performance of an Os engine. |
Would the HPI car be the best and easiest to convert into a bigger block engine without having to replace a bunch of parts? I am interested in doing a project like this to have a fast straightline road car. I know you can get the HPI car pretty reasonable. It does have a decent .18 in it, but know where near as good as say the OS TZ .18 (Modded) Any response or help with a project like this would be appreciated. Also if anyone knows where there is another thread on here that goes over alot of this type of project, please let me know. Thanks for any help.
Originally Posted by BChiz
(Post 11957839)
I lost contact with him as he had moved. He built my Ld3.However,I had installed a 2spd,an had to offset the fuel tank in an angle,Also had to put an aftermarket rotostart set up,because there was no room for a big bulky pullstart.The header an a marine muffler had to be used also. So a big block can be installed with things shifted around,an different parts used.My friend made his own chassies though. I |
Who makes the Ld3. I'd like to take a look at that. Thanks.
(Post 11958120)
they are metal,which the Ae ntc3 uses plastic,an I dont know what Hpi run in their drivetrain. Ofna diffs can handle the punishment of the torq. of a big block engine. I got all of my Ld3's on ebay,an every now an then,they do pop up for sale...Oh,they are a shaft driven car:cool: |
Hi Car-Tune. Appreciate the video post. Great running car. Could you possibly post a pic of the car less the body. I'd like to see that O.S. TZ 18 in there. Thanks.
Sorry. Motor is not installed http://www.rcuniverse.com/forum/webk...3ed2/imagejpeg
No big deal. Maybe when you get it back together. Thanks.
Hey Car-Tune, what kind of pipe are you using and who did your engine work? It really sounds mean. Thanks.
1 Attachment(s)
Motor was work on by some guy I met online and did his work for drag racers. I haven't spoke to him in years
thr pipe is ERCM.extreme RC mods |
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2066144Here's my cf chassis
Hi Car-Tune, I appreciate the posted pics. I would also be interested in things you have modified to the car as it is now. Feel free to P.M. me if you want. Thanks.
Ive upgraded everything on my car and I do mean everything
CF chassis CF F/R shock tower CF upper chassis All steel shafts ported O.S 18tz battery stronger servos titanium screws F/R diffs 19/26 pinion Ceramic bearings disk break fuel filter air filter motor mounts titanium turnbuckles aluminum shocks Buku clutch ERCM pipe weight balance of car 4 wheel alignment wheel balance and more |
Thanks alot for pics and info. Where did you get your drive shafts and what did you do to the F/R diffs? I am thinking of doing one, but just for high speed runs, not for drag racing.
The drive shafts I bought them from eBay and they turned out awesome. No more breaking them. When I bought my rs4 I had the evo 3 which is the cheapest version and came with aluminum diffs do I kept eating them up so I had to upgrade them to steel.
i also wanted my car for hight speed runs but realized I will not hit 100mph unless I use a .21 engine. high speed run vid of my car http://youtu.be/-u-ZAyMXw_w look through my channel. There's more. |
Originally Posted by Car-Tune
(Post 11967215)
i also wanted my car for hight speed runs but realized I will not hit 100mph unless I use a .21 engine. high speed run vid of my car http://youtu.be/-u-ZAyMXw_w look through my channel. There's more. I need to get some vids of my car.I would have to take my car to a less traffic spot.One twich or mishap,it would be abliverated...:p |
