yokomo GT4
Hello i have a yokomo gt-4. I am driving it with a os .18 which has 31,000rpm. standard shaft engine?
1. What is the fastest gear ratio i can use between the spur gear and pinion gear? 2. What is the right right spur / pinion setup? 3. Do you have a gear ratio chart? 4. Also do you have the mathmatical forum formula to calculate the speed of a car? 5. What are the best tires for the gt4? 6. What offset can the gt4 use? 7. What are the best foam tires? 8. How do i get the yokomo to stop fish tailing? 9. If you have a website or link that could help me with all this, please let me know? |
RE: yokomo GT4
ttt
ttttt |
RE: yokomo GT4
the reason it is fishtailing is because yokoma is a drift company their cars are all set up for drifting
