Autonomous ROVER on the Tri-Track Chassis
Hi guys,
Never actually built my BOT as I ended up getting a RC Helicopter instead, but the project was as follows...
For a while I had planned to build an Autonomous Robot, based around the Tri-Track Chassis...
[link=http://www.active-robots.com/products/platforms/tri-track.shtml]http://www.active-robots.com/products/platforms/tri-track.shtml[/link]
I had proposed to use the ooPic micro-processor.
I chose this Chipset as you can program the EEPROM using a variation of Visual Basic!
How better to program the BOT and its autonomous features! I have alot of commercial programming expertise, so this was a natural choice.
The EYES of the BOT would be a rotating Turrett that housed a CMUcam2 camera.
The Cam can be programmed to track colours/objects/movement etc.
An excellent demo Video of the Cam following a coloured object can be found here..
[link=http://www.youtube.com/watch?v=9NL3Aglr-Pc]http://www.youtube.com/watch?v=9NL3Aglr-Pc[/link]
Also adding IR and Sonar sensors, for greater range, and a method of roaming the environment and "learning" where objects are, for navigation around a room etc.
CURRENTLY...
Mixing robotics and radio control, I'm very interested in building a flying Drone - Glider or Winged craft - Bit like the military Predator.
Incorporates a micro-processor that is linked to a GPS module and an Accelerometer.
So the craft would be able to fly a course without assistance, to a waypoint or location specified, using its onboard GPS.
Could even add a Cam so it will take video or shots, as it flys over its course, or when it reaches a waypoint. Would be a great project!
CURRENTLY...
