PWM help
<span class="Apple-style-span" style="font-family: Verdana, Arial, Helvetica, sans-serif; "><table class="forumline" width="100%" cellspacing="1" cellpadding="3" border="0" style="background-color: rgb(255, 255, 255); border-top-width: 1px; border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px; border-top-color: rgb(0, 102, 153); border-right-color: rgb(0, 102, 153); border-bottom-color: rgb(0, 102, 153); border-left-color: rgb(0, 102, 153); border-top-style: solid; border-right-style: solid; border-bottom-style: solid; border-left-style: solid; "> <tbody> <tr> <td class="row1" width="100%" height="28" valign="top" style="font-family: Verdana, Arial, Helvetica, sans-serif; background-color: rgb(239, 239, 239); "> <table width="100%" border="0" cellspacing="0" cellpadding="0"> <tbody> <tr> <td colspan="2" style="font-family: Verdana, Arial, Helvetica, sans-serif; "><span class="postbody" style="font-size: 12px; ">Hi, I am new here and was wondering if someone might be able to help me with a question. My robot is homebuilt on wheels. I want to steer the bot with an electric window actuator (from a car) The motor turns much to fast to control so I want to use a PWM to slow it way down. My question is what size PWM do I need.(size =volt and amp rating)
Here are the specs of what I am using ~Sealed Lead-acid Batteries (12v12ah/20hr) 2 in series) ~Dorman 741-814 window actuator (Just the 12 volt motor!) ~DPDT switch wired for reverse to turn wheels left and right (servo attached to run remotely) Links to products used: http://www.energexbatteries.com/prod...ah%7B47%7D20hr http://www.amazon.com/Dorman-741-814.../dp/B000E347L6 http://www.radioshack.com/product/in...ductId=2062530 Thanks for any advice. Also if you have a better less expensive approch I will take any suggestions.</span></td> </tr> </tbody> </table> </td> </tr> </tbody></table></span> |
RE: PWM help
ORIGINAL: Daddysharky The motor turns much to fast to control so I want to use a PWM to slow it way down. My question is what size PWM do I need. (size =volt and amp rating) You may want to start smaller. These places all have good kits and parts: http://www.pololu.com/ http://www.trossenrobotics.com/ http://www.acroname.com/ Getting back to your first question. The size of the speed controller depends on the voltage and current required for your motors. -Dave |
