crawler question?
RE: crawler question?
Is the steering servo attached to the esc or receiver? I know one of the small crawlers is set up so you have to install a new servo and esc if you want to upgrade. And you might try castle creations for a better setup.
LA
man with out a doubt go with the insane 370 motor by losi, i did it to mine and it has a lot more power plus the drag break worked better. dont bother going brushless and its only like $15. you wont be Disappointed
LA
i got mine from the lhc but you can get them online. yes it works with the factory esc no problems at all. i was shocked how much differance it made with this motor. just type in insane 370 motor and it will pop up.
