integy crawlers
integy crawlers
besides the normal integy sucks statments, does anyone have any input on the integy crawlers?
anything that i should know?
here is a couple pics of it
RE: integy crawlers
ORIGINAL: bigdogkanicsar
Seems you alredy know the most important information.
RE: integy crawlers
LOL^^
with ANY crawler, adding weights to the front wheels or axle helps.
i havent seen an integy up close, but how are the tires? are they soft? what of the foams?
with the redcat rs10, the stock foams are too stiff for crawling. i just took them out, what a HUGE difference. making the tires softer lets them form to the rocks and grip better.
does that rig have 4WS?
does it look like you might be able to swap the steering links from the front of the axle to the rear?(BTA mod)
it may not be the best super crawler, but that doesnt mean there are not some simple mods that will make it fairly capable.
and half the fun is modding anyway!
OH, how old is your kid? i have a 8 month old boy and he crawls around after my rock crawlers when i drive them in the house. keeps both of us entertained!
RE: integy crawlers
ORIGINAL: nitrosportsandrunner
LOL^^
LOL^^
it does not have four wheel steering, however the only thing i need for that would be a rear steering servo and 3 channel radio, all the linkage and steering blocks are already there.
i agree modding is half the fun and i have some plans for her already, like i am going to make custom tvps, battery tray, radio tray,
lower links, and possibly a custom cage instead of a body.
my baby girl is only 2 months old so far, but this will be #3 for me, and my wife has twin red head girls so altogether that's 5 kids.
i am excited for the baby to start getting mobile though. she is already a barrel of fun. lol
thanks for the tips
RE: integy crawlers
the tires are soft enough but the foams are a little on the stiff side.
thanks for the tips
LOL^^
LOL^^
thanks for the tips
you have front, 4 wheel crab, 4 wheel opposite, and rear.
if you get a 3ch radio you can have 4ws with the rear controled by a 3 position switch(full left, centered and full right)
but you can also use a "Y" cable and use the stock 2ch radio. you will have full-time 4 wheel steering, and you have to setup the rear servo to function opposite the front. but its not hard to do.
believe me when i say that 4ws is way more fun and that it makes a rock crawler far more capable!
i have my 8 month old boy, and a 9year old step daughter. its nice to have 2 kids, and even nicer with the age difference. i try to get my daughter into RC, but like her mother they just dont appeal to her. thats why i had another kid!
RE: integy crawlers
I have an Axial AX10 RTR crawler, andi put the 4 way steering on it by using the "Y" wire you have mentioned but i had a problem with it, when the truck was not moving and i steer to either side and press the throttle the cralwer didnt move, but my ESC lights red as its being in use, i had to let go of steering for it to move again. so i took the 4 way steering off of it now works fine, any idea why this would happem
RE: integy crawlers
ORIGINAL: moezer
I have an Axial AX10 RTR crawler, andi put the 4 way steering on it by using the ''Y'' wire you have mentioned but i had a problem with it, when the truck was not moving and i steer to either side and press the throttle the cralwer didnt move, but my ESC lights red as its being in use, i had to let go of steering for it to move again. so i took the 4 way steering off of it now works fine, any idea why this would happem
im not positive, its just a guess. you can get an external BEC, or a higher grade ESC.
RE: integy crawlers
i think its possible that the BEC on the ESC wasnt strong enough to run 2 servos and the ESC. BEC takes voltage from the battery to power the Rx and the servo. by adding another servo more voltage is being drawn, thus the RX doesnt get the power it need.
ORIGINAL: moezer
Sorry bigdog for stealing ur thread :P
RE: integy crawlers
ORIGINAL: moezer
is there a way to go around the BEC? i changed the reciver to a duratrax 3 channel reciver that i had in my nitro rc buggy would that work? i havent tryed it yet and i dont even remember what reciver i had in it hahahaha.
ORIGINAL: moezer
RE: integy crawlers
it's a definite that i will invest in a 3 channel or 4 channel radio(now that you pointed out full right, center, or left).
also wheel weights are in the mix later.
all this takes me some time cuz of the rarety of cash.lol
RE: integy crawlers
RE: integy crawlers
no harm in trying that, but if its the ESC's BEC that is at fault, changing the Rx wont help. if you have another ESC to put on and see if that works.
ORIGINAL: moezer
ORIGINAL: moezer
RE: integy crawlers
ORIGINAL: moezer
**** life it self is time consuming lool
