My AX10
CA
My AX10
Here's my AX10. Its taken a while to get to this point but so far its got:
Losi 4" springs with 40wt oil and white springs with Revo ends
home made 5/16" Delrin lowers (amazing stuff)
Axial underdrive gears (rear) and aluminum c-hubs
VP Hi-steer knuckles (going zero ackerman)
Novak 55T motor [:'(]
Mamba Max ESC
Hitec HS-645
some cheap BEC (it works!)
3S 800mah 30C Sky Lipo (amazing)
CW Crawlers Rocker chassis [my own design]
Hot Bodies Sedonas (F) Rovers (R) both white
some cheap plastic glue on rims till I make something nicer
Few pics of the car and the chassis:
(freeze frame from a video)
(I changed the home made tires on the front to Sedonas and cleaned the wiring up a bit )
Little vid, I got a better one ill upload shortly [8D] http://www.youtube.com/watch?v=EoLMRlerMnA (that's running the old tires )
Mamba Max ESC
Hitec HS-645
RE: My AX10
whats wrong with that motor? i should think it would provide good toque & wheel speed on 11.1v.
whats your runtime on 800mah?
i have a 3000mah 3s lipo i run in my redcat rs10. gets me over a half hour of runtime.
CA
RE: My AX10
Its pretty lacking in wheelspeed. For the moment im running it since I geared the chassis more towards noobs who run those motors but I have seen what a good 35T can do in a crawler and its insanity! All I can say though is that the chassis is absolutely nuts for my car compared to the ax10 stock chassis.
Hmmm about 20 mins "give or take" on how much im crawling. If im pulling a bunch of power demanding lines or putting the car in tight spots maybe 10-12 mins but on average I tend to do a mix of "tough and easy" so I can go about 20 mins. Generally my knee acts up before a battery dies . At about $10 a battery from Hobby Partz you can get a few and be set all day!
I don't know if you can see the video or not but here's a different video of it in action. http://www.facebook.com/video/video....84551211565581 The Sedonas KILL on the rocks, my rovers are worn and not as grippy but that's almost an advantage
RE: My AX10
but would you loose to much torque if you geared up the motor for alittle more wheel speed?
my crawler uses a pair of 70t 380motors. i know that sounds small, but at 70turns and geared low and pushing 11.1v they perform really well. a nice mix of wheel speed and torque. honestly if they had much more torque it would be a bad thing, as i would start breaking things
there has been snow up here for awhile. so having decent wheel speed is really good in the snow.
CA
RE: My AX10
I would, I know a lot of people who went from a Novak 55T to a "crawler made" 35T (hand wound, powerful magnets and so on) and it had as much torque as a 55T (generic) and also had killer wheelspeed so it won all around. I think it boils down to personal opinion but I have *COOKED* this motor before due to high gearing so its a miracle it even runs in the first place [X(]
For me ive sorta 'bulletproofed" my transmission so minus a MMM going in there, I think its going to hold up just fine All I can say is im happy with what im running at the moment, I am looking at a stronger steering servo though, the 645 is powerful but it seems to loose power when I need it most when climbing [&:]
RE: My AX10
if it seems like the servo is weaker when the motor is under load(climbing) then you probly need a external BEC. one that will provide 6v all the time to the servo.
the outcry ESC that i have came with a external BEC. which is really important on my rs10 since it is 4ws and has to power 2 servos.
CA
RE: My AX10
Nope I got that covered! the BEC feeds right into the servo, its just the 645 doesn't have the torque that others do. It still works so im not grumbling there but overall it could be better
CA
RE: My AX10
Here's a Youtube vid of the car in action in case the Facebook link didn't work (and its a lot longer)
[youtube]http://www.youtube.com/watch?v=5OtFOU-a00Q&feature=player_embedded[/youtube]
I love how WORN my rear Sedonas are in a good way, helps prevent the back from getting TO much grip
CA
RE: My AX10
ORIGINAL: rickb-123
you did a great job looks good
Made a few in Aluminum up and blasted them with Aluminum Oxide and we get...
