losi comp crawler
losi comp crawler
Hey dudes iv been after a crawler for some time now,
after a bit of research i narrowed it down to the losi comp an the axial ax 10 scorpion,
but after owning losi,s in the past i thought stik with what i know
am i making the right choice?
any input would be sweet !
cheers guys..
ps
will be running brush-lipo..
cheers guys..
ps
RE: losi comp crawler
Is this just for backyard bashing/casual crawling? The Losi is really meant for competing. It does not like brushed motors. They get really hot, really fast. Even my brushless setup gets pretty damn hot running longer than about 10 minutes at a time. Battery life is relatively short for a crawler. The typical 1100-1500mah packs that guys run only last about 20 minutes whereas they'll last upwards of 45 minutes in an AX-10. Like I said, they're meant for competition where you typically only run for about 5 minutes at a time.
The Losi has a built-in dig unit that requires you to have a 3rd servo. Even if you don't use the dig, the servo needs to be there to keep the dig from slipping outta gear.
On the plus side, it is a pretty kick-ass crawler. Competitively speaking, it blows the AX-10 outta the water. But just for casual backyard crawling, the AX-10 is probably the way to go. It's very versatile. It will run just fine on brushed motors and it will run for a long time on small 1100mah batteries.
prob casual but yer never know )
cheers for reply.
ps
its a done deal piking up a LCC tomorrow with losi brushless set up an lipo,
so il soon findout!
cheers for reply.
ps
so il soon findout!
Well i piked up my brushless LCC last nite an i gota say wat a top bit of kit !
took a while settin up my dx3r with it but i think iv sussed it,
anyways had a little drive of it on a cpl of obstacles an im well impressed )
this sucker grips an climbs like a champ,
cant wait to get it on the rocks ....
The Losi CC will work great with a decent brushed motor. I am running a Fantom Blitz 35t hand wound in mine. It NEVER gets more than warm even after 20-30 minutes of running. I fried 2 expensive brushless motors before i tried the Fantom. I would not go back to brushless after this motor with a CC Sidewinder.
Adam
Adam
wow yes, the Losi comp is an amazing machine. the weight distribution on them is fabulous. tested them against my CR01 and no comparison what so ever.. i love it!
