Servo's
MI
Servo's
just checking if anyone has any suggestions on what servos i should get to replace the stocks in my redcat rs10 ? keep in mind i am not going into any competitions or anything like that so i would like something that is not to pricey.
Thanks in advance for any help
-Mike
RE: Servo's
Get some Savox 0251mg's. They produce 222oz of torque and only cost about 35 dollars. The only issues you might have are they don't work well when powered off a esc and they are about 1/4 inch taller.
MI
RE: Servo's
what do you mean when you say power off from the esc ? my servo wires are ran directly from the servo to the reciever, are some rc's hooked into the esc instead of the reciever ?
-Mike
-Mike
RE: Servo's
The esc powers the receiver in most cases. But a esc cant handle high draw setups. To fix this problem you can use a receiver pack to power the receiver and servos or a external bec. To run such setups you need to disconnect the red wire on the esc plug that goes to the receiver.
