maxstone wheel upgrade
I'm unfamiliar with the maxstone 10 wheels, do they have a hex, (and if so, what size is the hex?), or a pin? You should be able to buy aftermarket wheels, check with RC4WD. Also, what size tire do you have?
Not sure what you mean by make them larger? you can buy bigger tires to fit the rims you have also you can buy bigger rims and they would need bigger tires. not sure if yours has 1.9 or 2.2 size rims. but first i think you should check the tires size and we can go from there.
Its a 2.2 it looks like an axial ridgecrest almost.
Anyways, if ur wanting a taller tire the rc4wd Baja claws are a tall tire and are 2.2 but I think they come in 1.9 also. I have them on my axial wraith and they kick ass. Lots of bite another great tire is the pit bull rock beast.
