Roc Hobby Magnum - 1/18 Ford F1 RTR
Another model is on the way from one of the most prolific RC crawler manufacturers ever.
A 1948-1950 Ford F1 (First Generation F series) that uses Roc Hobby/FMS's proven aluminum 'C' channel frame and their Chevy K10/Glacier wheels and tires.
Tires are 19.2 x 13.5 x 56mm Cooper Discoverer tires. No official sneak peak or promotion has been seen anywhere in the normal channels except
it was available as a Pre-Order on several sites in the UK, Australia, Belgium.
Since stock Ford F1 trucks were two wheel drive only, this makes it a truck outfitted with factory optional "Marmon-Herrington All Wheel Drive."
Now this truck is available, showing in stock as I write this: https://www.mcmracing.com/en/home/18...it-ROC11814RTR
And here: https://www.beez2b.com/en/cat/15320-...TR-ROC11814RTR
Roc Hobby Magnum 1/18th RTR ROC11814
Roc Hobby is proud to introduce our latest 2022 product; the 1:18 Magnum, a highly detailed RC scale vehicle modeled on a popular post-war design, featuring a spacious and comfortable cab with realistic dashboard and seats.
A wide sill extends under the door and a flat one-piece front windshield, coupled with a larger rear window, provides a more wider view. Put your hand on the five chrome-plated cooling grilles where you can explore the
cleverly-integrated turn signal lights. The spacious rear cargo compartment and openable tailgate make loading and unloading of cargo convenient.
Roc Hobby 1:18 Magnum, a classic scale off-road vehicle from yesteryear ready to impress RC enthusiasts with its hard-core chassis, suspension and classic appearance. Equipped with a strong and reliable aluminum alloy beam,
Magnum adopts four-link suspension and thrust bar design, which efficiently and precisely conveys steering. Shock absorbers are made of stainless steel springs and with the new wheels and tires, it provides not only the charm of
a classic car but also provides notable off-road performance.
As always, this brand new 1:18 Magnum uses ROCHOBBY typical splash-proof electronic system including independent servo, two-in-one receiver and ESC, 2.4G remote control with a distance of up to 30m, 050 large torque motor,
7.4V 380 mAh lithium battery for endurance and running time of up to 30 minutes!
Roc Hobby Magnum Features:
Injection-molded hard body
Functional hood
Scale interior features
Rhino bumper kit
High traction M/T tire with 1.0 inch internal bead lock wheel
Realistic pinion & ring gear axle
High torque transmission with 104:1 FDL
Water resistant electronics with 2.4GHz radio
High torque over-sized 55T brushed motor
7.4V 2S Lipo battery providing up to 30 minute run time
Chassis- mounted servo
Aluminum frame rails
Tuned coil shocks
Roc Hobby Magnum Specifications:
Radio Control: 152 x 75 x 167mm, 160g (Battery not Included)
Model Vehicle: 328 x 149 x125 mm, 570g(Battery not Included)
Tire: D:56mm, W: 19.2mm
Wheel Base: 196mm
Ground Clearance: 38mm
Approach Angle: 30°
Departure Angle: 44°
Driving Speed: 5km/h Max
Remote Distance: 30m
Play Time: 30 minute
WHAT’S INCLUDED:
1 x 1:18 Magnum RTR
1 x 2.4GHz Radio
1 x 2-in-1 Receiver / 20A ESC (installed)
1 x 050 Brushed Motor (installed)
1 x 1kg Plastic Digital Servo (installed)
1 x 7.4V 380 mAh Battery
1 x USB Battery Charger
1 x Hex Wrench Socket
1 x Product Manual
NEEDED TO COMPLETE:
AAA Batteries for Radio
Functional hood
Rhino bumper kit
Tuned coil shocks
Wheel Base: 196mm
Approach Angle: 30°
WHAT’S INCLUDED:
1 x 1:18 Magnum RTR
1 x 2.4GHz Radio
1 x Product Manual
NEEDED TO COMPLETE:
I say Roc Hobby/ FMS/ EazyRC is a prolific manufacturer because they churned out this list of trail trucks, crawlers and super scale replicas
in rapid fire.
Roughly in order of appearance:
RocHobby 1941 MB Scaler 1/6
FMS Atlas 6x6 1/18
RocHobby Katana 1/18
EazyRC Patrion renamed Patriot 1/18
FMS Suzuki Jimny 1/6
EazyRC Arizona 1/18
FMS Toyota Land Cruiser 80 1/18
RocHobby Fire Horse 1/18
FMS Toyota FJ Cruiser 1/18
EazyRC Triton 1/18
FMS Suzuki Jimny 1/12
FMS Willys MB Jeep 1/12
FMS Chevrolet K10 1/18
EazyRC Glacier 1/18
FMS Toyota Hilux 1983 1/18
RocHobby Kubelwagen 1/12
FMS Kommandeurwagen Beetle 1/12
FMS Mogrich Unimog 1/18
EazyRC Bronx (Bronco) 1/18
RocHobby Cheyenne 6x6 1/18
FMS FCX24 Power Wagon "1/24" (Actually scales to 1/18)
RocHobby Magnum 1/18
in rapid fire.
FMS Atlas 6x6 1/18
EazyRC Arizona 1/18
EazyRC Triton 1/18
EazyRC Glacier 1/18
Did some calculations, and if this 1/18 model represents an 1/1 Ford F1 with a standard 6 1/2 foot bed and a 114 inch wheelbase, I get a scale of 1/14.7735
That's 1:15 scale.
That's 1:15 scale.
