RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Tamiya TLT-1 into crawler
Reply
Old 05-06-2004, 07:58 PM
off-roadkill
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tamiya TLT-1 into crawler
how do u make a TLT-1 into a crawler? how much would it cost? has any one done it? love to see pics
thank for the help
off-roadkill is offline
Old 05-07-2004, 02:05 PM
custom monster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tamiya TLT-1 into crawler
I don't thank it has been before and I thank that if you were going to do it you would have to do it mostly from scratch. You would have to make it wider and have more ground clearance and you still would have to make it more powerful.
custom monster is offline
Old 05-07-2004, 02:33 PM
RcRock-Guru
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It can easly be done here is a link to the best one i've seen.
http://www.gerrish.net/tlt1.htm
He even made it into a 6x6. ALso check out his vids of it in action.
RcRock-Guru is offline
Old 05-08-2004, 06:24 PM
CustomClod
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The TLT-1 is just a smaller version of the TXT-1 and the TLT-1 looks like a good crawler out of the box. Check out the following link and you will see what I mean.
http://www.tamiyausa.com/product/ite...oduct-id=47201
CustomClod is offline
Old 05-14-2004, 04:17 PM
Jason Beach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TLT's are excellent for crawling. Other than chassis clearance, they crawl well right out of the box.
Costs depend on how crazy you want to go.
Here's a TLT crawler I reciently sold.
TLT-1 axles
Stampede tranny
Geolander tires on Stampede wheels
custom Plexiglass chassis
Jugg yokes
Jeep body
You can find a small video here.
Comentary by my son. [X(]
ID:	132345   Click image for larger version
ID:	132346   Click image for larger version
Jason Beach is offline
Old 05-20-2004, 09:11 PM
flip3d
flip3d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where can i get a body like the jeep.
flip
flip3d is offline
Old 05-27-2004, 10:02 AM
Isphius
Isphius's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think im going to get one of these andmake my own 2.2 crawler...what i was thinking was use a stampede gear box and turn it sideways, drive the 2 axles, make my own chassis, but what bodies can i get in 1/18th scale? theres not really a market for them. please offer some suggestions
Isphius is offline
Old 05-27-2004, 07:16 PM
flip3d
flip3d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have one for sale.
check out it on the off icial rock crawling page.
page 27.
flip
flip3d is offline
Old 06-04-2004, 11:59 AM
zaxon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check my half finished TLT-1 I'm making it bigger
zaxon is offline
Old 06-06-2004, 06:21 PM
t-maxx homie 369
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does anyone know any way i can lift it higher off the ground because its not crawloin too well with like a half an inch of ground clearance
t-maxx homie 369 is offline
Old 06-06-2004, 06:37 PM
zaxon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes use t-maxx turnbuckles and kyosho dogbones and t4 turnbuckles and t4 shocks to extend and left
zaxon is offline
Old 06-08-2004, 06:22 PM
Wookie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It can definately be done. I've had my TLT-1 for about a week now and am well on my way to turning it into a serious rockcrawler.
Here is what I've done so far:
Stretched the wheelbase out 1.5" and raised the truck .75"
Total cost $13.50
Parts needed (traxxas 82mm turnbucles #2337 (4 sets) and one set of HPI 6x57mm Super Nitro RS4 dogbones).
Cut 4 turnbuckles down to 71mm and leave the other 4 the stock length. Replace the inner turnbuckles with the 71mm Traxxas turnbucles and the 82mm ones replace the lower turnbuckles.
Then take the HPI dogbones and dremmel one end of them down (just the ball end). You will need to remove approximately .5mm of surface from the ball end (leave the dowls alone). The undremmeled end goes in the center differential drive cup and the dremmeled end goes in the axle drive cup.
Replace the 25mm pushrods for the suspension with the inner 47mm rods that you just replaced.
You will need to lock out all 3 differentials. Use JB weld to lock them out. This is permenant though, but they will be super solid.
Other parts I've added:
Integy 55 turn lathe motor ($19.00). This motor is super high torque and gives excellent run times. For crawling it's the motor of choice in the TLT-1. I get 25+ minutes out of my Tamiya 1700 mAh pack. With a GP3300 saddle pack you should get 40+ minutes of run time out of it.
22 tooth metric 48 pitch pinion. With this pinion and the Integy motor I get a top speed of around 8 mph, but can climb anything.
HPI 5 spoke RS4 MT wheels ($24.00). Make sure you get two sets of the ones for the RS4 MT as they have more offset than stock wheels which will widen the wheelbase approximately .5".
IMEX G-Hawg tires ($36.00 for a set of 4). These tires are 4.75" tall and 2" wide. They add another .75" to the height of the truck (with the lift kit mentioned above I have 2.25" of center clearance at the bottom of the chassis). The provide excellent grip and have no clearance issues when turning (due to narrow width).
Remove the servo saver and replace it with a solid mount. The servo saver does nothing but hinder your crawling ability and when your top speed is 8 mph you really don't need it if you are using a good metal gear servo.
Replace the bushings with bearings.
That's all that I've done to mine so far, but I am working on a new mounting platform for my ESC and receiver so fitting a saddle pack into the chassis won't be a problem. I also have other ideas for the transmission, maybe lengthening the wheelbase a little more and going with a carbon fiber chassis.
I've included some pics of what mine looks like now.
ID:	141170   Click image for larger version
ID:	141171   Click image for larger version
Wookie is offline
Old 06-18-2004, 11:17 PM
zaxon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THIS IS MY TLT-1 COME CHECK IT OUT[img][/img]
ID:	144883   Click image for larger version
zaxon is offline
Old 06-22-2004, 10:48 AM
t-maxx homie 369
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wut upgrades have you done to yours zaxon
Old 11-06-2004, 03:57 AM
pedy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Wookie
Total cost $13.50
ORIGINAL: Wookie
That's a pretty easy and cheap stretch to do.
You need:
(4) Traxxas 82mm turnbuckles (Part #2337 I believe)
(1) HPI Super Nitro 57mm dogbones (Part #A553 I belive)
Step 1. Cut 2 sets of turnbuckles down to 68mm and the other two down to 79mm.
Step 2. Dremel one end of each HPI dogbone down so that it fits in the drive cup on the axle.
Step 3. Place the shorter links on the inside and the longer links on the bottom.
Step 4. Take the 47mm links (from the inside of the stock links kit) and replace the stock 25mm pushrods with the 47mm links.
That's it. Should give you about 1.5" of stretch and about .5 to .75" of extra center clearance.
i think this is where the problem lyies[:@] so is it the shorter one?
pedy is offline
Old 02-25-2005, 09:35 PM
jimsip1071
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wookie,
Will those Stamped wheels and tires fit on a stock TLT or do you need the extra lift too. I want to do one upgade at a time.
jim
jimsip1071 is offline
Old 02-25-2005, 10:43 PM
rockdragon
rockdragon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did turn my TLT-1 into a serious 2.2 rock crawler and I named it .... Silver RockDragon. [>:]
.... 13" wheelbase .... over 3" of ground clearance .... almost 90 degrees of articulation ....
http://img135.exs.cx/img135/9260/sil...gon10008wu.jpg
http://img123.exs.cx/img123/7325/sil...agon0031wi.jpg
http://img123.exs.cx/img123/4043/sil...agon0046ri.jpg
http://img210.exs.cx/img210/4060/sil...agon0029rx.jpg
Most of my knowledge to turn it into a serious 2.2 crawler is from here ... http://www.rccrawler.com/forum/forumdisplay.php?f=20
rockdragon is offline
Old 02-26-2005, 02:05 AM
Mike01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There's an article in the magazine section of this site (How To's) that talks about how to build a TLT with a lot more articulation and clearance with mostly stock parts.
Here's the link:
[link=http://www.rcuniverse.com/magazine/article_display.cfm?article_id=482]http://www.rcuniverse.com/magazine/article_display.cfm?article_id=482[/link]
Mike01 is offline
Contact Us Archive Advertising Cookie Policy
