my first crawler...design stage.
GA
this is my crawler idea... using TLT 1 axles, 2.2 wheels and tires and a fully welded frame made of aluminum rod, a scratchbuilt tranny and a seriously hacked up HPI rubicon body this is what I came up with. now keep in mind these axles are just for the concept. and there a few small issues I will address, mainly concerning the placement of the steering servo (as it might get hit by the front axle when it's fully compressed). but no real problem areas that I can see. please give any tips or ideas for improving as I plan to start building the chassis monday.
RE: my first crawler...design stage.
thats some nice CADding there boy...
I was bothered by the steering servo at first then I read your text above a little closer... :P
does 3dsmax have real world measurements? will you be able to actually use the plans? How about the obligatory "articulation Shot" - which seems to be the money-shot for crawler fans!!
This page takes ages to load and I have a T3 leased line connection... how about a 56k warning on the Title someone as i would be well miffed if I was trying to view this over dialup.....
GA
I'll use the body as a template to make the frame...and scale it all as I go...it sounds more complicated than it is...
GA
only way I know is buy the whole kit...then you get the tranny, some test wheels, shocks...and LOTS of screws for your project too!
LA
i sent a pm i think anyway i was wondering if it wasnt to much to ask if you could design a dual engine hpi rs4 3 ss on your cad system because my auto cad doesnt perfom the things i need it to do. if not thats ok where could i obtain the program you have? thanks. Tim.
Crisp Motowerkz
Crisp Motowerkz
GA
I can do it but I'm kinda swamped with stuff already...the program is fairly expensive and has pretty stout security so I don't think it's available other than buying it.
LA
could you possibly send me a copy with limited features? is that even possible? i just want to be able to designt the chassis and everyhting... the same thing you have done. but im only 15 i do have connections to a machinest so i can get the parrts made but i cant design them i dont have the correct program autocad sux i think
GA
it won't work...the program needs an auth code and serial number to work and if I give you mine then my copy won't work. it's registered with the programs maker.
