What will happen if you jump a crawler (like a max climber)?
RE: What will happen if you jump a crawler (like a max climber)?
well my friend jumped his makeshift e maxx crawler and busted all turnbuckles and tore his gear
FL
In theory, a crawler shouldn't be able to go fast enough to fly. But, with the right mix of terrain and speed anything is possible. I guess carnage will depend largely on what the truck was built with and of course the speed upon impact. I whopped my TTR Ripper today directly on the front bumper, no damage...[&:] Kind of nerve wracking, it almost fell in the ditch![X(]
PA
ORIGINAL: tamiyakid08
i have seen a tlt go off a ramp b4, it will land it ussaly.
to ur question, u can jump it if u want, if its a good crawler it wont go fast and it should be pretty beefy so if u liek jumps at walking speed....then go for it
OR
If it's a good crawler, it wont jump. Crawlers by definition are S L O W. You need a bit of pep to get up obstacles, but jumping is not part of the equation.
ryan
ryan
AE, JAPAN
I've decided to get a T-maxx instead of a Max Climber since I have a big yard that isn't mine (which means I can't put rocks and stuff on it).
Thank you for the info. I appreciate it.
good choice on the t-maxx with a couple of spools a t-maxx can be a crawler too that will do 40 when your done with the pile of rocks..
CA
I'd have to agree that crawlers don't jump. They'll fall, tumble, roll, drop, twist, crunch, roll, etc... Basically, they'll take a beating. One outing and a new body is beat-up. My Gecko II runs 19 turn reedy motors and gear reductions. Top speed is slower than a walk.
BTW, I don't know that an E-Maxx has enough clearance/articulation to be a true crawler.
m
m
every one says that this truck is bad at crawling cause it lacks flex or ground clearence. while these qualities are nice i have a jeep tj that can flex a 836 on a rti ramp with 32s and open diffs and hve seen a old 4runner with flex of like 400 and 30s that had a clse to stock ride height and locked front and rear diffs do every thing i did on that trail he banged a body alot more ber he still made it so flex and cleance help a lot but traction is key.
