Nylint 1/6th scale Rock Crawler
#101
RE: Nylint 1/6th scale Rock Crawler
LOL i to bought some krylon fusion black and a can of purple and green mirage and it looks fantastic.
so now it changes colors on the way by. will post pics soon.
I will also be getting a video on it going up a very steep cement wall.
about 50 feet up almost vertical.
need about a week wont be getting cam until tomarrow.
#102
I have had to fix a few things on My 1/6th. I pulled the pass side shaft out and rana weld around it, i then groud it down so the bearings would fit back on, it seem to be holding much better than the stock shat and cup. on my small one i put a toyota tacoma concept body on it so it did not look like the big one. Notice in the 1/6th the gauge cluster and heater controls and where the park brake was it now has transfer case twin sticks.
Does anyone know if they are going to be making upgrade parts for these thing in the near future?
#103
My Feedback: (14)
NY
they have upgraded to some better axles and such but you can only get the upgrades if you buy a whole chassis. I have a first generation and with all the walmarts out of stock around here looks like i won't be getting an upgraded one from walmart but we can order direct at funrise.com to see if you have gen 1 or 2 look at the shocks they will be screwed in both top and bottom for the gen 2. the upgraded gen 2 has better axles with more metal in them instead of plastic.
#104
IL
Hey Jefferson1964
What store did you buy yours from?? I bought one last night at full price[] Charging the battery now Could you or would you fax me a copy of your receipt. I could get two for the price of one[8D] Would have a hard time explaining that one to the wife Hi Baby,no thats not another car
ORIGINAL: Jefferson1964
Well walmart lowered the 1:6 from $149 to $119 and now $75....i got cash back all the way down using my reciept. Based upon what i was told here i purchased the Krylon Fusion Black and Forest Green. Dissassembled the body took off the stickers and painted and put it back together. It looks much better with the green body. I have not posted pics before but will give it a try......for $75 bucks and two cans of paint this is the best value out there IMO......just need some rocks to climb....none around where i live......
#105
MD
i started to do some upgrades. i built a steel roll cage and am now working on a steel frame. my pics are at www.mikegardner.myphotoalbum.com .i have not yet figured out how to post pics here.
#108
CA
I got a 1\6 and drove it for the first time today... after about 15 min. I snapped the metal peice on the inside of the front axle... Anyone had this problem yet?
#109
MD
no not yet but my steering knuckles are all messed up and the metal ball that is the axle has stripped the hub out . now when i turn under pressure it locks into a left only turning. i got my revo w/ a jeep unlimited rubi body!!![>:]
#110
CA
yah i think my steering was messed up as well... sometimes it would just steer from left to right all the way to lock... not sure, i mailed it back to walmart.com but still havn't gotten a reply from them recieving it yet. with my luck this is gunna take a real long time to get another.
#111
I just painted mine today. I have drilled hole in the rims, cut the little tabs under the support arms. Added limit straps and put o-rings on the drive gears.
#112
WI
Heres my truck "ruttenMuck". Been good so far.My steering trim is irritating me though, evrytime the truck stops,I have to adjust trim or it will just sit there and hum forever! Put L.E.D tailights in with a center councel mounted switch hooked up to a 6 volt power source.Headlights and roll bar lights comming soon!
#114
CA
ORIGINAL: poe
can they go in Watar
#115
Well Here Is My "RIG". Hope You Like It!!
MODS: Full Body Paint, LED Head Lights & Tail Lights Powered By 4 "AA" Battery Pack with Center Counsel Switch, Diamond Plate Panels, Padded Roll Cage, Rear Canvas Cover, Rear Mounted Spare Tire, and I Switched The Front Tires To Reverse The Tread Pattern To Increase Tire Traction When "Crawling" (IT REALLY WORKS!)
#118
Here is a before and after picture of my nylints TT.
Before: http://img84.imageshack.us/img84/2100/p42000211zy.jpg
After: http://img228.imageshack.us/img228/4620/p42200282jb.jpg
#119
WV
Not much done to mine, just tire cutting and reversing. It did make a bit of difference. The pic compares the 1/6 Nylint to the New Bright 1/10 scale crawler.
#121
JUST BELOW THE WINDOW WHERE YOU PUT YOUR POST IT SAYS " upload images and files!". CLICK ON THAT AND AWAY YOU GO!!
btw caps means you are shouting....................
#122
I'm a noob here and was reading the thread about the 1:6 scale Rock Climber. I just bought one (Jeep) at my local Wal-Mart last night. They were closing them out for $49.98 ea.
I brought it to work with me and I'm messing around with it on and off. Seems to be quite the climber.
A couple of months ago, I also bought one of the Ultimate Soldier 1:9 scale Abrams Tank. It's a blast to run. So....between my Jeep and my Tank, I'm good to go......for a while.
Later..........
Later..........
#123
I run mine in the creek behind my house and have yet to have it even jam. Everyone who has broken thier axles jamming in the rocks all i have to say THEY AREN'T HOBBY GRADE DON'T THINK THEY ARE THAT'S HOW YOU BREAK THEM.[sm=bananahead.gif]
#124
GA
here are a few pics of my stock 1/6. . i have some videos i'll b putting up soon!
oh and sorry about the all caps yelling thing. i didn't know. . .
[img][/img]
[img][/img]
#125
GA
man, i was crawlin around on some rocks the other day and broke half of the bead lock off the right front tire!
and i have inboarded the rear shocks for greater articulation! its awsome. and i will be painting the whole thing soon! so stay tuned!
i'm glad i found this website! i have no one to talk to about them or play with here... if there is anyone who lives in atlanta who wants to get together and run them let me know! i also have nitro rc trucks!!
