Nylint upgrades?
IL
Nylint upgrades?
I am new to this and was wondering if there are any upgrades for the nylint. Also does any one have any pics of CUSTOM nylints. thanks
TN
RE: Nylint upgrades?
ORIGINAL: f150_offroader
CO
Stretch the wheel base out, bigger tires, change shock mounts. I will try to post some pics of my Scorpion w/2.2's. I have been so busy trying new things out I have not done 1 pic of it yet. There are a couple of ways to stretch out the wheel base. I am in the process of doing the extended arms and already have the extended pivot point.
http://www.rccrawler.com/forum/showthread.php?t=16514 This shows quiet a few mods.
Toby
Toby
FL
I keep up with mild modded TLT's!
enjoy:
CO
I used these wheels, http://www2.towerhobbies.com/cgi-bin...&I=LXJH63&P=RF the mod was very simple. I cut a long 1/4" allen wrench and put a point on it, put it in my drill press, heated up the allen wrench and pressed it down thru with the drill press. Then I ground down the back of the wheel flat. It is a perfect fit. I will try to get some pics posted soon. Then all you need to do is use a flat washer. I am also running Swamp Dogs wo/foams. Been running bb's in them but think I will go to the stick on weights.
Toby
Toby
CO
I took a piece of tin and drilled holes to mount them. The advantage is that when the axle drops, it is in a rotatoinal way, so it gives it more travel with a shorter shock.
Toby
Toby
