new clod
GA
RE: new clod
Looks pretty mean[sm=punching.gif]. I like to fab things myself. I've spent gobs of time and money on my TXT, wish I had started w/ a Clod though. I'm not far from you I'm in Winder(YEE-HAW)[sm=bananahead.gif]
RE: new clod
00 cool finaly some one responded, and its not a major crwler its just until i can aford the geko chassis....it took me two days to build it..
MO
RE: new clod
man the best chassis are the home built ones because youre the only one with it. it seperates yours from the others im not saying dont buy one just think how much better it is knowing you built it from scratch. Ive had my clod for 10 years and built four or five different chassis for it and it only gets more trick and better. just keep going it gets better.
AZ
RE: new clod
c-crum Looking good c-crum to me thats what it is all about the accomplishment and self pride in doing it all for your self and nobody else. Keep-up the good work man.[sm=shades_smile.gif]
RE: new clod
thanks im not using it for that much crawlin mostly crawling on wood piles fallen down trees and things like that...those links are strong i fell off of a 4 or 5 foot ledge on the front left tire and only broke the the plastic link mount wich is now aluminum and all the steering links are covered with brass tubing to strengthen them up a bit..thanks for replying... and the stock tamiya motors suck on torque,what motor should i get...
MO
RE: new clod
hey i finally put rear steer on it...ok the way i hooked the servos up is unique i dont have 3 channels or a y harness so i took apart the receiver and modefied the batery input and hooked it up to the 1st channel ,and now for the second servo i hook it up to the battery input...
MO
RE: new clod
RE: new clod
I'm runnig Axiom 65t and 55t's. They are the smoothest lathe motor I have ever ran. They are only a few bucks more and there is a huge difference in proformance. You have alot more control through out the power band for sure.
RE: new clod
ccrum, that looks like one strong chassis. Nice job on the whole truck! I agree with the others about fabricating your own design. It's such a reward, and indeed it is unlikely someone else has the same.
dez, that body is sweet!
