Nitro Rock Crawlers Only
#401
UT
RE: Nitro Rock Crawlers Only
Guess Ill just use my stock engine then...:P
And I will find a way to get over the nitro rc crawler hump (literally and figuratively) forget all this cant do and wont work...there is always a way...
#403
WA
Well, I don't know if this thread has ended. If it has ended and I just found it.... Bummer. I have been working on a Nitro R/C crawler for about a month now. I am using a Tmaxx 2.5 chassis and drive train. The chassis is going bye bye in place of a hand made aluminum chassis. The one off print drawing and measurements have been a bear but I am finally making some head way with manufacturing (and designing it so it's appealing) the chassis. I have locked the front and rear arms and as soon as I have the first chassis built I will work on the 4 link system. I have read through the feed and seen some haters, but mostly some serious ideas I will use on my own rig. I am going for the horizontal mount for my motor, but I think i am a few months away from that process. I soon will be locking the diffs, and the transmission is a whole other story. As far as over heating goes... I have tested quite a few different applications. I wnet with a standard CPU fan, this worked fine for a Maxx in standard motion (i.e. fast) But ripping it around my backyard at a slow pace, but keeping the RPM's up seemed to bring the temperature up higher than I wished. I am toying around with the idea of purchasing a CPU liquid cooling system. My idea was that the CPU coolers come with a small radiator, micro pump, and cooling fan which a runs the cooling gel they use and I have heard it really sucks the heat. With a little tweaking with some cooling tubes possibly wrapped around the head you could bring the heat down drastically, and could be powered with a four cell rechargeable unit. The whole deal would not weigh all that much and is a fairly small set up. What do you think? Have you tried this? Is it possible? ?
#405
Ok im gonna try and get this thread going again, i have been watching this as a guest for a long and im gonna try
try and build a nasty nitro crawler so please lets keep this going. ok im at the stage where im trying to design
an a chassis and i have taken alot of ideas from here, i'll tell you all what i work out...
#406
MO
Not exactly comp worthy, but here is a nitro powered crawler that actually doesn't work half bad.
http://s491.photobucket.com/albums/r...t=MVI_1166.flv
Now, if you can get rid of that annoying sound.
#407
That is a decent video and one of the most promising I have seen to date. Of course, my work PC has no sound so it was nice and quiet to me!
As for my truck, I am going to halt the production of the cooling and fuel systems and focus on making it run as an electric. I have put countless hours into the cooling reservoir and fuel tank along with their mounts, but I need to head in another direction if this thing is ever going to see the ground.
I finally picked up a radio that will be used with my steering so I can continue that and hopefully get some video of the system's operation. I have also begun the shock machining so I can post some pictures of that.
The decision to drop the nitro power for the time being is simply to allow me to see it run much sooner. My place of work may end up having its plug pulled and my shop access along with it. That would cripple my progress.
Oh well.
Oh well.
#411
ORIGINAL: The Real Dogman
I fixed it for you Hands!!
ORIGINAL: hands without shadows
Doesn't exist. You have to build one yourself!! It will take years!!
#412
What ???? You have never seen that new Prius Hybrid Electric Crawler ???? LOL.....Sorry....I just couldnt resist....I am done now.
#413
Seems that this thread hasnt had any action in a while. I to would like to build a scale crawler some day. Gas or nitro, doesnt matter as long as it isnt electric. Doesnt seem real to me if it doesnt have an engine. How is everyones projects comming togeather?
#414
MO
ORIGINAL: Fordtrucks96
You could always mount a Parma Hemi engine in your electric crawler to make it more real.
#415
lol thats a good one. I dont have a crawler period. I have a 1/8th nitro MT and thats it. I think of one wanted a gas crawler that a gas to stroke for better yet, a 4 stroke is whats needed. Nitro is to much of a race engine to me.
#416
whats up guys, I'm a novicein the crawler world and I want to build a nitro crawler, where can I find a chassis set up that will support a.21 without having to make one? also I'm looking for advice on gear reduction and transfercases, do I need a tranny or does the gear reduction box take it's place? if anyone could help me out that would be great, maybe some websites or something, also too what type axles would be the best? thanks guys, this site is amazing
#417
Just a heads up there are some people on this forum that would just as soon shoot you than allow you to make or buy,if you could find one, a nitro crawler.
Kevin
Kevin
#419
ON, CANADA
ORIGINAL: ChuckCharleston
What I'm trying to get across is that we cant definitevely answer questions like that because your pioneering. You need to research to make decisions for yourself and ask really specific questions if you want this to become a reality.
#420
Hi guys it has been awhile and I have been pondering the nitro crawler issue and I may have found a solution to the problem. i am going to try this as soon as I get some more money. I am looking for 2 Tmaxx chassis, Tmaxx and an Emaxx transmission. I thought while playing with an Emaxx I got my mother who is in a wheel chair from an automobile accident in Hawaii why not use both the Emaxx and the Tmaxx trannies. I have decided to try and mount the Emaxx transmission up first since it is 2 speed shiftable Hi and low range this would be like a transfer case and then mount the Tmaxx transmission next since it has shiftable reverse. I would set the Tmaxx transmission like it is foc'd forward only conversion by locking the gears so it would go without jerkiness and when shifted into reverse it would go still giving you the brake on the Tmaxx tranny. The gearing is the issue I am working to figure out in both transmissions. Those are the issues I have at the moment. I believe I can set the spur gear and the clutch gear similar to an electric motor and I believe I can eliminate the slipper clutch on the Tmaxx transmission. I think I can use electric motor type gears to connect the two trannies together. I will let you know what I find out as soon as possible. my axle set up will probably be kyosho mad force axles since I think they can be 4 linked easily. I will let you know what I come upwith Laterz.
#421
The gear reduction - Mine is 400-1 for an engine that revs 20000 - 25000rpm
I have been working on the nitro lately and have addressed the clutch and steering. The clutch is now completley custom shoes with a harder spring so it can idle nicley and the steering now has zero ackerman blocks. I will get some pics and a fresh vid up soon.
Matt
Matt
#422
ok guys dont know if anyone is still reading this forum but i work in a machine shop so i can make many of my parts. i started with a t-maxx 2.5r ive left the front stock for now the rear is the same diff,axels, and knucklesbut removes the ifs stuff and ran 2 alluminum 1/2 in dia roads across. i mounted the 4 link to this and the shocks. i changed the trans to metal unit. added a servo on top of the rear axle for the 4 wheel steer and a switch on remote depending on if i want it to turn the same or the opposite as the front. now the for the best stuff the motor is now a 32 cc weed eater motor. the tires arefrom a 1/5 scale to helpkeep them from spinningas much. i first made this truck for pulls but it work for most of thecrawling i do. ill try toget some pictures if anyone want to see it
#424
ok these pictures are a lil old befor the exhaust was done and the air intake problems where fixed. the 4wheel steer servo is also not installed yet.
