1/24 rock crawler BIG PICS WARNING
RE: 1/24 rock crawler BIG PICS WARNING
ok haven't been here in a while sorry for delay in replies... the suspension has "dummy" lower links that do nothing but look cool... the upper link is actually the axle links and spring all in one. the upper links are made out of green plastic banding material... cut into 1/4" strips... they allow enough flex up and down but keep the axle centered during articulation. there is no traditional spring. the shocks are actually travel limiters (both up and down). and the drive is made with a servo and a few pinion gears for a transfer case.
oh yea the wire thingys you see comin from the brake calipers are guitar string used as scale brake lines...the front ones are rubber so they dont bind the steering.
