OFFICIAL WHEELY KING CRAWLER THREAD
#551
RE: OFFICIAL WHEELY KING CRAWLER THREAD
For those interested I just updated my Wheely King ad with new complete photos (pics of everything).
12 detailed pics in the post:
[link=http://www.rcuniverse.com/market/item.cfm?itemId=397557]Click to see ad and all photos[/link]
Make me an offer, I need to sell this.
i got my servos from hong kong in just under 2 weeks. i deleated the record in my ebay account, otherwise id give you the name of the seller i got mine from. could be the same as the link i posted, but i cant be sur.
#554
glad to see this thread is back. not sure what happened but at least its back. i havent really messed with my king lately. i think before i do anything else with it, i will get a higher turn motor. which would be best to get? i want a little speed for bashing so i was thinking like a 35 turn. i want something about like the stock motor but with more torque. any suggestions?
#556
do you guys think 6 cell ener-g 4600 nimhs are too much for the stock motor and esc? i plan to get a wheely king soon and want to keep it stock except for any mods that are a must. i wont be competing just want a basher for my backyard that can pop wheelies at will
#557
the motor will be fine on that battery. the esc will run, but get hot. may shorten its life. the stock esc is only good for a completly stock wheely king. if you try to crawl or make it run faster(ie, lower turn motor or much better battery) it will get hot. plan on upgrading the esc in the near future.
#558
My Feedback: (17)
IL
hey guys glad to see its back. i was starting to think i got kicked off fo some reason. well i bought a servo mount from ebay it was a older ckrc mount and wont fit with my stock tires, so got pissed and took a alumnin brownie pan from the ole lady and made one. kinda thin but its workin so far. ive got one ? can i run 2 1500 batteries?? if so how do you wire them 2gether?? and thanks for all the help from everyone. its been fun building my first crawler
#559
You will want to wire them in parallel. Basically you will have the positives of both packs connected to the positive on the ESC, and the negative of both packs connected to the negative of the ESC.... he best way to do it is to make a little adapter with two battery plugs on one end that both connect to the single esc plug on the other end. (positives together and negatives together.)
#560
My Feedback: (17)
IL
ORIGINAL: dacaur
#561
ORIGINAL: dkchance74
that will leave it at 7.2v and change it to 3000 right. thanks
ORIGINAL: dacaur
Right
#563
VA
no problem. I have seen this done before. It actually is nice because it lowers your center of gravity. Good luck and lets see some build pic's along the way.
#565
ON, CANADA
I've made it. It works quite well with shorth shocks and a lot of weight in the wheels. Dont use the stock shocks, the ride height is way too high and it results in some weird axle wrap issues.
#566
My Feedback: (17)
IL
ORIGINAL: hands without shadows
#569
if you arnet using a 2.4ghz radio, you NEED caps to suppress electronic noise or you will most likley get glitching... if you are running 2.4, you dont NEED them, but i would still put them on...
#573
BC, CANADA
My novak 55 came with caps on it and I got my ax 10 with a tazer 15t esc but bought a rooster crawler right away and couldnt be happier. The zero delay and higher amp bec is awesome especially when you are running a high torque servo.
