OFFICIAL AX10 Thread
#77
CA
RE: OFFICIAL AX10 Thread
Finally got my AX-10 going & it's a BLAST!! I brought it to work & it climbs over just about anything in the shop,including the lifts,tires,boxes,batteries,etc.This thing should be unstoppable as soon as I get all the parts for the Stage II mod.Just have to trim the body a bit more cuz it hangs up due to the massive articulation.Are there longer body mounts that I can use to install the Proline Bushwacker(Landcriuser) body I've already painted up? It's a bit wider than the original B-17 Betty.
#78
TN
is the rtr any good ? im looking @ buying one , b/c theres no summer racing at my track this year , , what are the need to get upgrades ? , thx joe
#79
VA
Hello,
Here's my completed AX-10. Here's what I've added so far:
Novak Rooster crawler combo
Hitec servo
moved battery to front axle
Rock star body (Proline)
reused a Traxxas controller
Axial 30 degree links (waiting on second set to come in)
This was my first build it was a good time with no major challenges. I've done some preliminary test (Crawling over my kids!) and this rig looks very capable. I'm going to enjoy this truck and I can see upgrading becoming quite addictive!
QMAXX40
Hitec servo
QMAXX40
#81
I ordered a Stage II AX-10 and a bunch of add ons today
That means after all the work and money I put into the Wheely King I will be selling it and starting another project.
#82
UT
That bites... A lot of time was spent on that Wheelie King I bet... Well, As a nitro dirt guy, I'm getting to like this crawling thing!
The New Panther Crawler Tire will be released to the distributers who have already made orders on May 16th 2008!
#84
[quote]ORIGINAL: QMAXX40
Hello,
Hitec servo
QMAXX40
[/quote
i notice that your shock bumbers are on the outside of your shocks. it helps them alot to install them inside ,under the shock pistons! it makes them stronger and and lower the truck just a little for better center of gravity
Hello,
Hitec servo
QMAXX40
[/quote
#85
PA
i got the body painted up and its nice. I riped the hole b/c the body is so thin but hey w/e? Its a blast! I just plasti dipped the servo so a couple more grs till i can drive.
#87
CA
I've searched the forum but have not really found an answer as how to improve the pinion angle,especially when using the 30deg bent links. Is the the Stage II mod supposed to correct this? Should I either lengthen the upper links or shorten the lower links? Installing the upper links under the servo/4-link plate helped a bit,but the driveshafts still hang low. Does the new ARTR AX-10 come with updated axles to help correct the pinion angle? Thanks-Mike
#88
BC, CANADA
I do believe lengthening the upper links will help. If you can't find the answers here, I would also check Crawl Canada, and RCCrawler.
#89
TX
Here's a few pics of my current AX10
Novak Rooster + 55t
Futaba 2.4g FAAST tx/rx
CS-150 193oz servo
Losi 4" shocks upside down 35wt
MIPS CVD C-Drive Splines
Losi Rock Claws
10.5oz weights front / 6oz rear
split pack battery
30 degree links
Novak Rooster + 55t
CS-150 193oz servo
Losi Rock Claws
split pack battery
30 degree links
#92
TX
ORIGINAL: rye
hi
where did you get the grave digger body and what scale is it thanks rye
hi
I'll get you some part numbers when I get home today. I've done a dozen lids, but this one was by far the hardest to sticker.
#93
Hi all ,thought I would try my hand at building a droop suspension tube chassis for my AX-10.
Will most likely clean it up some more and give it a paintjob, but just want to try it out like it is just in case I want to make some changes.
#97
Ok I am still new at this and turned my ax10 into a scaler.. now the question is can anyone give me details in how to make my steering better as in a tighter radius ???
#98
CA
ORIGINAL: tac9227
I imagine you are still running the locked diffs. The HPI wheely King and RS4 gear diffs drop right in, and will decrease the turning radius substantially.
If you still need a tighter turn, the screws holding the C-hub mounts can be converted to countersunk heads with a little trimming and drilling. This will keep the steering knuckles from hitting the screw heads and give more arc.
#99
You have got what I want to build, where did you get the chassis and bodyshell?? Amazing though it sounds the AX10 is so good that I am now able to get over absolutely anything that I want to. The downside is that it is becoming boring, so having a scaler like that should make life more interesting.
Cheers
Rob G
Cheers
Rob G
#100
www.tcscrawlers.com/Chassis-Kits-p-1-c-103.html http://www.tcscrawlers.com/On-Sale-1...n-p-16556.html and I am gonna use a Rubicon body, trimmed and painted by RCHover in Foxboro Massachusetts www.rchover.com
