Here is my Gmade Stealth
WV
Well I figured I should post up a video of my Stealth as I have seen many threads wondering how capible/quality this kit is.
So here it is.
http://s158.photobucket.com/albums/t...t=stealth1.flv
BTW my friend and I have greatly helped the performance of it as of now.. It does need some things, but with some cheap tricks we made it crawl REALLY well.
I should have a video of it as it is now quite soon so you guys can see the difference.
Thanks and tell me what you think,
Aaron
So here it is.
Aaron
WV
RE: Here is my Gmade Stealth
Hmm ok well I got Maxx shocks, moved the upper link to where the (link mounted shocks) would go. And that REALLY helped it "breakover" because where they were before it wouldn't at all. I used "ducting putty" from ACE hardware for wheel weights(half a brick per rim[6oz]) so I have 2 lbs on the rims all together. Diffs are obviously locked. Tires aren't glued and are holding great. Little stuff like that makes this thing REALLY crawl.
I have yet to break a part on it so I haven't gotten to experience the wonders of Korean shipping!
I say they are fast shippers...quite fast...
sorry, my english is not my native...what did tou put in the wheels ???
post a shot with the shock mounting mod....
I have the SPIDER, and interested making better...I already lock the rear...I wait for a cheap solution for the front too...
WV
What I put on the rims was as I said "ducting putty" its for sealing ducts. It comes in 1lb bricks and was about 2$ for a brick.
If you have the Spider its not the same chassis as the Stealth so you would have to figure out your own link placement. I have never seen a Spider so I cant really help you there.
But I got some pics for you anyway.
Front:
Rear:
Front:
Rear:
PA
dont know i was setting it up when i blew the gears. [][>:][][:@] It did do good in my livingroom you know the subruban crawl. LOL the bm17's are killer powerful.
I just got a chassis fron www.tcscrawlers.com and so far so good. Still waiting on most of my other parts (servos, motors, esc, etc.) but the diff lock are absolutely necessary, only $19.00, cheap like Borscht.
Anyone have any recomendations for shocks? I keep hearing about a "droop" setup, what is that about?
