RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Rock Crawlers (http://www.rcuniverse.com/forum/rc-rock-crawlers-277/)
-   -   Axial SCX 10 (http://www.rcuniverse.com/forum/rc-rock-crawlers-277/10649679-axial-scx-10-a.html)
17dean 08-01-2011 11:36 AM
Axial SCX 10
Greetings , been into 1/10 Rc On Road sedan racing and drifting. just bought me a Axizl SCX 10 to appreciate rock climbing as well. Wanted to knowwhat kind of brushless engine I can get to enhance my speed as well as power too?</p>
K_B 08-01-2011 02:57 PM
RE: Axial SCX 10
You can get the Goat 3S with the 18.5T crawler motor. It'll scoot on 3S lipo and still crawl well. Or save yourself a little dough and go with a Tekin FXR brushed ESC and a 35T brushed motor. Same (if not better) performance than the brushless system and a bit cheaper.
phmaximus 08-05-2012 08:36 PM
RE: Axial SCX 10
How many guys here have these things?
I just picked up a Trail Honcho so far so good, it's the newer one with the 4 link rear.
I was looking at the spare parts bag, by the looks it's got all the parts to make the front 4 link. just needs 1long screw
But I'm worried that the servo will limit the flex anyway. Any one tried it?
Are the chassis mounted servo kits with panhard bars any good?
t9dragon 08-06-2012 07:28 PM
RE: Axial SCX 10
I have 1 SCX10 Cherokee.........
phmaximus 09-05-2012 05:28 AM
RE: Axial SCX 10
sweet post up some pics.
I got a 3 racing winch today... dammm its cool. ill get some pics soon with a little info on what I did to fit it to the stock trail honcho bumper...
I still need to Convert the 2ch switch on my Traxxas TQi controller from a on/on switch to a on/off/on switch to get it working from the remote
nitrosportsandrunner 09-05-2012 07:35 AM
RE: Axial SCX 10
most of the local guys run a traxxas waterproof VXL system on 2s lipo. Just gear the motor for the speed you want. Most of them swap out to 32 pitch spur and pinion gears.
Only downside of going the vxl route, is no drag brake.
You can gear up the stock motor for a few more MPH as well. I do this in the winter time when I crawl snow banks...as more wheel speed is needed for that. Then I gear back down for the summer when I crawl and rocks and need more torque.
zman5000 09-05-2012 03:34 PM
RE: Axial SCX 10
1 Attachment(s)
got one also looks realistic. got a traxxas brushless system and waterproof servo and it's chassis mounted with a drag link not a panhard rod.
phmaximus 09-05-2012 04:34 PM
RE: Axial SCX 10
Quote:
ORIGINAL: nitrosportsandrunner
Why would u use the expensive traxxas VXL combo where i could just run a cheap ezrun combo & they have drag brakes???? dont mean to offend but that sounds like a down grade.
and I cant stop thinking whats the point of swaping out the electronics for water proof stuff, then ditching the waterproof battery(nimh) to use a battery that does not like getting wet(lipo)???? I cant think why U would even need a lipo???
Im very happy with its speed it seems very scale to me, if anything it could be a little slower, might try a 55t motor.
Have u thought about running a 2 speed gearbox? I thought about it on mine, but it wont work with DIG, ive allready got the Axial Dig case, just need the gear set and servo... cant wait. it should be a true crawler with the winch and DIG
phmaximus 09-05-2012 04:49 PM
RE: Axial SCX 10
Quote:
ORIGINAL: zman5000
looks good m8, hey whats the advantage of the chassis mounted servo?
hey what do u mean by "drag link not a panhard rod" im confused, the drag link connects the steering to the servo horn and a panhard rod stops side movement of a axle... Dont thonk it would work to well wiith out a drag link
nitro stan 09-21-2012 04:24 AM
RE: Axial SCX 10
no advantage to a cms. just looks more scale with out a servo on the axle. if anything it takes away from front flex a little. the panhard hits the front pumpkin before full flex. i built my cms out of stock parts and a scrap of metal i had. biggest reason for me was because i wanted to be able to go into deeper water crossings,there are no real strong waterproof servos out there. iv tried to WP my own servos before and one died in the water.had water in it when i opened it up
people like the vxl system because its waterproof. ezrun isn't. i dont like sensonless brushless in a scale/crawler. it cogs to bad at low speed for me. i like my losi msc12l esc's and 35t motors, the losi esc has a crawler mode,lipo cut off(2s) and is water resistant. i put mine in a radioshack project box just to make sure it stays dry
nitrosportsandrunner 09-21-2012 07:34 AM
RE: Axial SCX 10
Quote:
ORIGINAL: nitro stan
yeh, chassis mounted servos look cool. But they do suck...lol. In certain situations they push on the suspension and in others you get limited steering in one direction. It is more scale looking tho.
The vxl being waterproof is great. It is a shame it doesnt have drag brake. The ezrun's are the way to go if you dont even intend to run your truck in the wet. The vxl can also be geared so there is little cogging and still have a fairly quick top speed...you know, for the mud or snow:)
zman5000 10-01-2012 04:27 PM
RE: Axial SCX 10
i made my own chassis mounted servo mount, and the plate i made out of carbon fiber also mounts the battery. i have real good artictulation and no bump steer much to the chagrin of the "know it alls" and withthe vxl setup with the 2075 servo you don't haveto stop for anything creeks and rivers included. i now run this rig on the trails in parks around here with plenty of water and mud and hills and when i'm done i take it home and hose it off with a garden hose, can't be any easier.
nitro stan 10-02-2012 05:41 PM
RE: Axial SCX 10
"yeh, chassis mounted servos look cool. But they do suck...lol. In certain situations they push on the suspension and in others you get limited steering in one direction. It is more scale looking tho."
a pan hard keeps everything square, and steering is the same both ways depending on your epa settings
phmaximus 10-10-2012 06:00 PM
RE: Axial SCX 10
I allways thought the pan hard rod kicks the diff slightly to the right?
and when that happens it turns the steering slightly to the right too. and what it moves it what it loosesin steering in the other direction
I cant see any preformance gains from chassis mounted servo...
zman5000 10-11-2012 04:06 PM
RE: Axial SCX 10
it's a drag link from the servo to the wheels and no i don't have bump steer or axle movement. this thing is just fun.
nitro stan 10-11-2012 07:55 PM
RE: Axial SCX 10
a pan hard is a link the connects axle to chassis. most connect to the passenger side of the axle and to the drivers side of the frame. when set up wrong the axle will move to one side under compression. set it up right and nothing moves.
the axle wont move without one, but the chassis will move when the steering gets in a slight bind,instead of turning the wheels
heres my cms with panhard
http://i38.photobucket.com/albums/e1.../Photo1666.jpg
http://i38.photobucket.com/albums/e1.../Photo1668.jpg
http://i38.photobucket.com/albums/e1.../Photo1670.jpg
heres my scx10
http://i38.photobucket.com/albums/e1...z/DSC00026.jpg
http://i38.photobucket.com/albums/e1...nmondz/sm4.jpg
zman5000 10-13-2012 07:11 AM
RE: Axial SCX 10
1 Attachment(s)
i've found that with a proper 4 link i don't need the panhard rod. nice truck you got
nitro stan 10-14-2012 07:08 PM
RE: Axial SCX 10
i see said the blind man, i should have asked if it was 4 linked, mines 3 link,and will move all over the place without a panhard. i managed to get it set up right the first try, so i never built the links to 4 link the front.
thanks man
bronco25ton 10-15-2012 02:41 PM
RE: Axial SCX 10
My "Y" link wore out quickly so I used the left over parts to convert the front to 4-link. Just had to come up with addidtional hardware to make the swap. It seems to work well.
phmaximus 10-22-2012 01:04 AM
RE: Axial SCX 10
Well here we go, finally got around to getting some new pics with the winch fitted.
I ordered the DIG case just need the gear set.... cant wait to get DIG cranking.
http://media10.dropshots.com/photos/...018/130207.jpg
http://media11.dropshots.com/photos/...018/130349.jpg
http://media11.dropshots.com/photos/...018/130421.jpg
aknitroguy 10-25-2012 09:46 AM
RE: Axial SCX 10
Quote:
ORIGINAL: phmaximus
The included four link mounts work great. They don't hit the steering plate at all. You need a 1-1/4" long 3mm fastener to mount them and four (per axle) 3x10~12mm fasteners where they mount to the axle housing. I used them on this build for a customer and they work great. http://www.rcuniverse.com/market/item.cfm?itemID=873593 I used 1/4" 6061 for the links and polished them.
phmaximus 10-27-2012 08:31 PM
RE: Axial SCX 10
Ah cool, how's the links in the spare bag were to long for the front and changed the diff angle [&o]
aknitroguy 10-27-2012 09:14 PM
RE: Axial SCX 10
Quote:
ORIGINAL: phmaximus
Yeah, you have to make your own links. The ones for the Dingo kit are 86mm. However the Honcho is a bit longer, so I'm not sure of the length. What I do is mount a link end to each mounting point and cut a piece of coat hanger wire to fit between them with the axle clocked to the desired angle, then get an exact measurment from that. I looked and axial don't seem to make them in the correct length. It seems funny that they would add the mounts and not make the right links to fit them. The spares you have would be quite a bit to long as the top links mount a bit forward of the lower link mount position. I tried that first and it puts the servo mount plate at about a 45 degree angle (as you have noted). The aluminum links for the wye (3 link) set up are way to short, I tried that also before concluding that I needed to make my own.
I could make a set for you, but I'm not sure it would be worth it after shipping charges. I have know idea what it would cost to ship a small package to you.
phmaximus 10-28-2012 07:57 PM
RE: Axial SCX 10
thanks for the offer m8, might take u up on that some time. Just a bit boke ATM, maby after xmas....
Its something i need to do the bush in the 3 link top arm has a fair bitof slop these days.
Hows my local track has a crawler track there, man these SCX10's kick ass. it was to easy.
http://www.hobbyhabit.com.au/librari...er%20track.png
aknitroguy 10-28-2012 08:44 PM
RE: Axial SCX 10
Quote:
ORIGINAL: phmaximus
Maybe put a aluminum ball in the three link, they fit a bit tighter and might take some slop out of it. That is the biggest problem with the three link set up, they get sloppy and everything wobbles around.
That is a very cool crawler track! I love the volcano back drop. I am fortunate to live a few blocks from the woods, there are dirt bike trails and crawling rocks close by. It would be sweet to have an indoor set up like that for winter. I am doing a full set of honcho links for a rc buddy and I will have the exact measurments for your upper links. I will pm them to you asap.
Cheers.
