How to Cut Tire Foams
1 Attachment(s)
When building a crawler you want your tires to be soft enough to grip the rocks, but still support the weight of the truck. There are several ways to modify the foams to do this… cut the foam in half, pie cut the foams, or do a star pattern as I am going to show. For me, this method yields the best results.
The first step is to use a marker and divide the foam in to 4 even sections. http://image.rcuniverse.com/forum/up...52/Xv64445.jpg Then 8... http://image.rcuniverse.com/forum/up...52/Aw70265.jpg Then 16.… http://image.rcuniverse.com/forum/up...52/Dj11895.jpg And finally 32... http://image.rcuniverse.com/forum/up...52/Sl27740.jpg Then mark a circle about ¼ to ½ up the side of the foam. http://image.rcuniverse.com/forum/up...52/Hs96018.jpg Then with a sharp pair of scissors, cut from the outside edge of 1 line to the inner diameter (you drew) on the next line over. Then from the next line back down to a point with the previous cut. It should look like this… http://image.rcuniverse.com/forum/up...52/Zq97213.jpg Do this all the way around and it will look like this… http://image.rcuniverse.com/forum/up...52/Pr26446.jpg And you will have this left over. http://image.rcuniverse.com/forum/up...52/Rq56298.jpg This takes a bit of time, but will give you the extra bite on the rocks you need.[8D] |
RE: How to Cut Tire Foams
Another A+ how-to. Thanks for the info!
i was wondering how to get that pattern, thanks for the how-to!
I am trying to get these how-to's as stickies..... So a little bump was in order :D
Awesome how-to! This is great info considering a crawler is up in line for one of my next 2 RC builds.
first off thanks for the write-up! It was a big help today.
Second, I did this to my moab 2.2s and use an xacto knife to all doing the cuts to moabs. I also got a tear in the foam and when I was putting it back in the tire it ripped in half so I stuffed some paper towel in the crack and hopefully it will solve the issue. |
this is how I like to cut my foams.
http://i41.photobucket.com/albums/e2...J/DCP01994.jpg http://i41.photobucket.com/albums/e2...J/DCP01993.jpg |
coy5840, is that a "secret" chassis I spy. I cant pm you but I did spot it right?
Yeah what the hell is that in the background? it looks badass! PICS!!!!!
1 Attachment(s)
Here is what I used for foams. Team Trinity "Bomb Three" inserts. You also need Multi stage tire glue so the triple stage foams stay together. Careful as to what glue you use or the foams won't flex. What I like about this setup is that the tire flexes more and you get a solid tire patch to what ever surface you run them on. The foams are wide enough for sidewall strength too. Best way to describe it is an inner run flat system. You can see the difference in the size in the pictures.
how do you do this with black foams[:@]?
ORIGINAL: madmax22 how do you do this with black foams[:@]? You mean to mark the lines? How about a white or silver paint marker? |
ORIGINAL: Acs_guitars When building a crawler you want your tires to be soft enough to grip the rocks, but still support the weight of the truck. There are several ways to modify the foams to do this… cut the foam in half, pie cut the foams, or do a star pattern as I am going to show. For me, this method yields the best results. The first step is to use a marker and divide the foam in to 4 even sections. http://image.rcuniverse.com/forum/up...52/Xv64445.jpg Then 8... http://image.rcuniverse.com/forum/up...52/Aw70265.jpg Then 16.… http://image.rcuniverse.com/forum/up...52/Dj11895.jpg And finally 32... http://image.rcuniverse.com/forum/up...52/Sl27740.jpg Then mark a circle about ¼ to ½ up the side of the foam. http://image.rcuniverse.com/forum/up...52/Hs96018.jpg Then with a sharp pair of scissors, cut from the outside edge of 1 line to the inner diameter (you drew) on the next line over. Then from the next line back down to a point with the previous cut. It should look like this… http://image.rcuniverse.com/forum/up...52/Zq97213.jpg Do this all the way around and it will look like this… http://image.rcuniverse.com/forum/up...52/Pr26446.jpg And you will have this left over. http://image.rcuniverse.com/forum/up...52/Rq56298.jpg This takes a bit of time, but will give you the extra bite on the rocks you need.[8D] |
Are you using memory foam? and are you cutting anything off the o.d.
This is a great post thank you and kudos. |
