RE: OFFICIAL WHEELY KING CRAWLER THREAD
yep that would explain it :D
hi everyone im new to rock crawling and i picked up a used WK that some one had already tryed to convert anyways i've been redoing all the half a** stuff the other did
i have one ? when i'm testing it out on some little boxes and stuff some times my rear steering will turn on its own, does this just happen on all or is there something i need to fix? thanks for any help when i get home ill post some pics to see if you guys can help tell me anything that isnt right thanks |
I havent noticed that happening... is there a lot of slop in the rear links? some people have converted their rear links to a setup similar to the AX-10....Seems a pretty simple solution to me, and is what Ill be doing if i find it to be a problem...
ORIGINAL: dacaur I havent noticed that happening... is there a lot of slop in the rear links? some people have converted their rear links to a setup similar to the AX-10....Seems a pretty simple solution to me, and is what Ill be doing if i find it to be a problem... |
couple of pics of the king pullin the crawler
http://i173.photobucket.com/albums/w...hoctane020.jpg http://i173.photobucket.com/albums/w...hoctane023.jpg http://i173.photobucket.com/albums/w...hoctane016.jpg |
Nice set up. Hats off to you dude. How many colors of paint do you got on the Chevy body? Look's SWWWEEEETTTTT.
yeah thats a nice setup there. thats one of the best "scale" wheely kings ive seen.
Does anyone know if there is a company that makes a tuber frame for the WK?
Also, can someone explain "droop" suspension? The definition, reason, and results please. Thanks. |
were did u get the jack stands
what website did u get the mini jack stands at
1 Attachment(s)
ORIGINAL: The Real Dogman Wolf, some people are using Tamiya Stays but my rod ends require something bigger, so I used 1/2" aluminum u-channel you can get at your local hardware or home improvement center. [link=http://picasaweb.google.com/TheRealDogman/WheelyKing?authkey=KVBM0R73K2Y]Wheely King Pictures[/link] |
I have been reading through these forums, but I guess I'm just not getting it, I have a new wheely king, How do i get the battery to mount up front? I've read about reversing the chassis, but I'm a simplton and I don't understand how to do it. Can someone please elaborate on that for me, and even some pics would be better. thank you in advance
the simplest way would be to buy an axle mounted steering servo mount, take the steering locking stuff off the REAR axle and put it on the front. Follow the instruction on the axle servo mount to mount it, take the steering servo out of the chassis and put it on the axle, then reverse the motor wires so forward is forward, and you are done.
Another Newb question,
If I put a 55T lathe motor in my WK, will I burn up my stock ESC? Thanks. |
No you wont.
Thanks.
Just wanted to let you know that I put my WK roller on ebay with lots of parts if anyone is interested.
it dosent crawl that good when its stock i have one i tyred to crawl when it was stock it didnt work well i just got the crawler converson now it works good:D
:D:D:D:D |
I want to turn my WK into a tuber. Is this a good enough set up for backyard bashing? The TCS Edge chassis and then using the Axial AX10 Locked Transmission Set #AX30487.
Will it work without too much fuss? |
1 Attachment(s)
my wheely king crawler
ORIGINAL: nos482 couple of pics of the king pullin the crawler http://i173.photobucket.com/albums/w...hoctane020.jpg http://i173.photobucket.com/albums/w...hoctane023.jpg http://i173.photobucket.com/albums/w...hoctane016.jpg [X(][X(] WOW SWEET |
thanks , heres another couple with the new tires
http://i173.photobucket.com/albums/w...Oct2408007.jpg http://i173.photobucket.com/albums/w...ct24080143.jpg http://i173.photobucket.com/albums/w...Oct2408010.jpg |
Hey look at that kid in the way, good thing I've got a high turn motor and low gearing... [&:]:D
http://www.fototime.com/143815CE5EB5144/standard.jpg |
Hey nos what tires are those? Are those aluminum wheels? How do the tires crawl?
what would be a good motor for my king. i dont want it to be so slow that it takes forever to drive between obstacles but at the same time, i dont want it to overheat because of not enough torque. what would be a good motor to get? preferrably under $30
