RC Sailboats For all your r/c sailing needs, post here.
Sail servo arm rigging
Reply
Old 01-09-2012, 04:40 PM
Rider/Writer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sail servo arm rigging
I am installing a Hi Tec HS-815BB sail servo in an old reconditioned Victor America 3. This servo comes with a long "sail arm" that attaches to the servo at one end and has two small holes in the other end for routing the sheet line. I would like to find a standard sail arm with rigging holes and/or pulleys on both ends and that mounts to the servo more or less in the center of the arm. I would prefer to buy one rather than fabricate one myself. My net searching has so far been in vain, can anyone steer me to a source?
Bob Pi.
Rider/Writer is offline
Old 01-12-2012, 06:20 PM
01VIPER27
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sail servo arm rigging
Outside hole is for the mainsail while the inside hole is for the jib sail. You will need to put an eyelet on the back where your servo horn will end up when your sails are full out. you will need to loop the Jib sheet line to that loop before it goes out to your Jib boom.
Some Vic owner have both sheet lines go out the back onto the deck where either lines goes through an eyelet or pulley block set on deck bythe transom.
01VIPER27 is offline
Reply
Display Modes
