RC Sailboats For all your r/c sailing needs, post here.
questions and suggestions - newbie
Reply
Old 01-21-2012, 04:07 PM
lchurch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default questions and suggestions - newbie
At a swap meet I picked up at 10 year old RC sailboat. It has 2 servos in it, labelled as Airtronics 94421. I also have a question about using them with a receiver from a 2.4 GZ 4 channel aircraft. If these servos work, can I use them with a modern receiver as is, or is a wiring change I need to make? This is headed to my grandsons, so I'm trying to keep my investment low.
If i do need to start new for the boat, what radio combinations does anyone recommend? I diid see a Futaba 2ch AM system with rec. xmit, and 2 S3003 servos. Looks like 100% of what I need (minus Lipo for rec).
lchurch is offline
Old 02-03-2012, 09:42 AM
Paulvive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: questions and suggestions - newbie
I have a Futaba T4YF FM two channel. Iuse it on all of my boats. my receivers all have crystals on the same frequency as my transmitter. I would strongly suggest using an FM transmitter to reduce interference.
Paulvive is offline
Old 04-16-2012, 11:35 AM
D_wilbur
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The older Airtronics servos may not work with the fast response of 2.4 gig radio. give it a try you mite get lucky.
D_wilbur is offline
Old 04-19-2012, 05:24 AM
HoverDown3K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Older Airtronics stuff had the + and - backwards from everyone else, so make sure you check the polarity is correct.
HoverDown3K is offline
Contact Us Archive Advertising Cookie Policy
