"J" class ( 1930s Amer. Cup ) Plan source ?
PA
After looking around the web I believe it would be less expensive for me to build another sailboat . The one and only was the " Ariel " a 36/600 class boat . For a dummy beginner it was a rather good sailer . Anyway, to the point . I'm looking for a source for plans for the 1930s era Americas Cup sail boats . I believe I have the experience to finish one . Plank on frame is not too tough . We have plenty of ponds and lakes in this area and since wind is free, sailing should be very inexpensive . Preferably in the 60 inch and up size . I do have some stainless steel fittings ( from the old Santa Barbara boat supplier ) and can also fabricate what I don't have allready. Any and all help would be appreciated .
Looking at your dialog back and forth in these threads , It appears that your all a pretty decent bunch of guys .
Thanks.
Mike
[email protected]
Thanks.
Mike
[email protected]
J Boat Class Plans Source
Hi Mike;
Greetings to you from the 'Valley of the Sun'.
I too love the old J Class boats of the 1930s. I found a plans source from the AMYA web site many years ago, and sent away for a set of plans for the L.Francis Herreschoff designed 'Whirlwind', the only J Class double-ender hull design. The Plans source is:
Mr. R Serrao,
650 Ketch Harbour Rd.,
Portuguese Cove, Nova Scotia
Canada B3V 1K1
The plans are beautifully drawn, at 3/4"= 1', and he has drawings for all 9 of the legendary J Class boats. Why not drop him a line.
Also, check the AMYA site, and see what they have available in the J Class area; I have not visited there for quite some time now. Anyway, I hope this lead is of help to you, good luck, and best regards from sunny and real hot Phoenix,
Joe Nagy.
Mr. R Serrao,
Canada B3V 1K1
Joe Nagy.
PA
The " Ariel's " bottom !
Sounds wierd doesn't it ! Oh well, from what I remember she was very round, kindof barrel like . But she sure sailed well . It had to be about 20 years ago . Wish I still had the plans . I'd just double them in size and have at it .
I'll tell you from first hand experience that she would hold an adult's weight when in the water . The way I found out was that she had taken on some water and was circleing so I figured I would just strip down to my shorts and swim out to retrieve her . The water was colder than I thought and by the time I got to her I was exhausted . So I wrapped my arm around the keel and slowly paddled in with the other arm . Made it ,bit only because of the boat .
I do remember that she was very easy to build . Planked with balsa and glassed inside and out . I would definately recommend her for a beginner as she was easy to build and yet fairly easy to rig and sail .
Thanks to all for your help.
Mike
Mike
