RC Sailboats For all your r/c sailing needs, post here.
cutting a hull form from styrodur
Reply
Old 09-27-2012, 03:59 PM
GLX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default cutting a hull form from styrodur
Hi,
I've done a hull with that foam before and was happy with it but it was not very accurate in that I sanded both side of the hull and corrected by eye and touch to get a uniform shape on either side of the centreline.
This time I'm looking to do something different and as i have a little more time in my hand I wanted to try a different way to get my hull shape. Siri I've see your post re a 65 trimaran cut in sections. looks good but don't you get straight sections between the blocks which you need to sand down then to get a nice continuous deck line ? by doing so you'd loose some width of the hull right ?
I'm gonna try this on the BP5 float and see but wanted to have your views first since you've done this method already.
Ernst builds his with foam too but in a continuous block - I'm curious how you cut your foam ? you seem to draw your lines on the foam but then how do you cut accurately ?
Thx,
G.
GLX is offline
Contact Us Archive Advertising Cookie Policy
