Foiling Mini40 Tri - My FireDragon Foiling
Hi all,
there was sufficient wind, so I decided to do my first foiling tests with the v-foils attached - flying is fun
[youtube]http://www.youtube.com/watch?v=cEHH6C26Eas[/youtube]
Cheers
Roland
Cheers
Roland
RE: Foiling Mini40 Tri - My FireDragon Foiling
Here is the latest clip with even more foiling action
[youtube]http://www.youtube.com/watch?v=hBsA9ieYj50[/youtube]
Cheers
Roland
Cheers
Roland
Roland,
cool foiling action! congrats to a well designed foil assist mini40.
can you share some details on the foils? what is the weight position? How much from the aft (or front) is the foils mounted?
Is this video with sym or asym foils? What is the length of the profile, what the thickness? 10% or less? What is the length of the foil itself?28cm or longer? What angle from waterline are the foils mounted?
I am asking all these details as I am also trying to find a good foiling setup and I find it extremely difficult to find a good generic setup that would also fit for regatta (round course) scenarios.
Many thanks for sharing any details.
Eric
Eric
ORIGINAL: egi1610
Roland,
Eric
Roland,
Eric
I'm using an asymmetric foils, the foils can be obtained from rcsails.com .
[youtube]http://www.youtube.com/watch?v=aE_tARZoJGE[/youtube]
[youtube]http://www.youtube.com/watch?v=LBdyGBWKu0A[/youtube]
[youtube]http://www.youtube.com/watch?v=eDM85FYv04w[/youtube]
Cheers
Roland
6th European Multihull Open - 29.6-1.7.2012 !
www.mini40.eu
29.6-1.7.2012
The 6. European Open for RC-Multihulls of the Mini40- and 2m-classes!
www.mini40.eu
29.6-1.7.2012
CA
<xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><woNotOptimizeForBrowser /></w:WordDocument></xml>I could really use some help build that type of foil. I tried ten years ago and was not very successful. Mine had a float out front the sensed the water level and adjusted the foil angle. Any hints? Thanks Gerald - http://rcspeedsailing.com/index.html
The setup is very simple - I use fixed V-foils on my boat. No need to actuate while sailing, just a one time setting of the angle of attack (around 1 to 3 deg).
Hope this helped you.
Cheers
Roland
Cheers
Roland
[QUOTE=Multihull;11504955]The setup is very simple - I use fixed V-foils on my boat. No need to actuate while sailing, just a one time setting of the angle of attack (around 1 to 3 deg).
Hope this helped
Cheers Hey Roland ! can you help me , I,m looking for wher I can bye a trimaran in Thailand ?? maybe a nightmare or shinobi , I tried to opend the page to rcsail but it dosent work
Roland[/QUO so I was hoping you mait be able to help me , cheers Bjorn.
Hope this helped
