RC Sailboats For all your r/c sailing needs, post here.
Volvo 70 Build Log
Reply
Old 01-24-2014, 04:26 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Volvo 70 Build Log
Hi all,
I am starting a build of a Volvo 70 yacht, so i thought i might start a build log. The project is planned to incorporate many features that are true to the real boats and new/unique to rc sailing. Some of the features I plan to incorporate are:
1. Canting Keel
2. Spinnaker/Gennaker
3. Moving Daggerboards (doubt this will make the final cut)
I have attached some of the photos of the build so far.
please note that this project is not designed to be true to scale, but more of an enjoyment of experiment of can it be done. So therefore a miss mash of parts will be used. A couple of details about the build so far. The hull will be based on the 2006-2007 race boat ABN AMRO TWO. Throughout the race it achieved the longest distance travelled in a 24hr period, which has since been surpassed by Groupama (now called Giacomo). I have purchased rather than build the appendages such as, keel, centreboard/daggerboard and rudders from german website stockmaritime.
Also don't while trying to do one project decide to play around with your old boat. Delays everything getting done on the new project.
Enjoy
ID:	1961523   Click image for larger version
ID:	1961524   Click image for larger version
ID:	1961525   Click image for larger version
ID:	1961526   Click image for larger version
some_bloke02 is offline
Old 01-26-2014, 07:51 AM
Orcatkt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking forward to seeing this one. I have been toying with this idea myself, still trying to convince myself to start though. Make sure to keep posting pics!
Orcatkt is offline
Old 01-27-2014, 11:31 PM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a few specifications on the boat.
LOA 1330mm
LWL 1227mm
Beam 285mm
Draught TBD
Displacement 4-4.5kg
Sorry of those who work in imperial measurements I don't have the conversions
I plan to construct the hull with a 2mm laminated balsa sandwich. Should be plenty strong enough but yet hopefully remain light enough to float at the design waterline.
My plans are from the website velarc.it, but acquired them through a file share in another thread on this forum.
If anyone is interested, http://www.filefactory.com/f/6e01e30cc7e3300b/
Currently working on cutting notches in the frames for the gunnels and keel structures. I must say it takes too long to cut a 3 x 6mm notch 3 times on each frame.
more to come...
ID:	1962756   Click image for larger version
Old 01-28-2014, 05:12 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which idea was that?
Old 01-28-2014, 10:30 AM
lucho_online1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, im luciano,from argentina, im building 2 of these vo70. im so glad to find same interests and will follow this thread...cheers
lucho_online1 is offline
Old 02-26-2014, 05:43 PM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'day
just a quick update. Finally managed to getting around to fixing the frames to the building board. Most are done, with the balsa frames of 1, 2 and the transom to go on. just need to find a way for them to be attached so they can then be removed from the building board.
hopefully this project will start moving along a bit quicker now. hopefully.
more to come.
Old 02-26-2014, 08:45 PM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Following on from the previous post. I have mounted the first 2 frames, and have nailed them to the MDF frame under neath. I also found I couldn't mount the transom for 2 reasons, first, in the lying around for 6 months or so, the transom warped and wasn't square, not helpful on a vertical transom. so i will remake the transom out of thicker balsa to hopefully ensure a straight and square transom. secondly the MDF frame for the transom was too high for my alignment points so will cut that down and hopefully remount over the weekend. I test fitted the gunnels to the frames as well, seem to all fit in, eventually.
heres some pics showing what i have described.
also included a picture in front of my car. all the time i have thought about this project, i had a tape measure out and thinking ah yeah this will be cool. now it has some physical presence to it makes it seem like a oh boy this is getting big.
ID:	1972966   Click image for larger version
ID:	1972967   Click image for larger version
ID:	1972968   Click image for larger version
Old 03-04-2014, 04:10 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question for some people more expert than me at boat building.
I am planning to sheet the hull instead of the more conventional planking method so I can laminate 2 layers more effectively, but in trial placements of sheets there seems to be too much twisting stress on the sheets to gain the desired shape. Should I plank instead of sheet, or just persevere?
Small update too, frames are all in with a new thicker transom, and a keel structure currently setting with 2 part epoxy glue.
Old 03-06-2014, 02:58 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brief update.
I have been working away over the past couple of days and have managed to have the keel and gunnels glued. I have also fitted and glued sheets where the hull has a chine. I wanted to keep this element as it was a pivotal part to me choosing this design.
I have also made some changes to my original plans. i will now be planking the hull instead of sheeting, i will still laminate it to around 2mm. I also couldn't accurately determine the angle for which the rudders are to the centreline, so I researched the rules for the full size boats. From this my interpretation is that the rudders can be angled 30 deg from vertical. From the last generation of designs it seemed the optimal angle was in fact about 15 deg from vertical. Maybe my interpretation is wrong. So now my rudders will be at approximately 15 deg from vertical.
Heres the link to the last version of the Volvo Open 70 Rules:
http://www.volvooceanrace.com/media/...mendment-3.pdf
Heres the link to the page where designs for most Volvo boats can be found:
http://chevaliertaglang.blogspot.com...design_17.html
I wouldn't recommend anyone attempt to build from those lines plans as the image quality isn't great.
But heres some more pics.
ID:	1975532   Click image for larger version
Old 03-23-2014, 11:58 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Progress on the hull has been slow of late, but nearing the halfway mark with the planking. Have also made some deck beams to help the hull hold its shape when it comes off the frames.
Just a few photos of the progress made.
ID:	1980826   Click image for larger version
ID:	1980827   Click image for larger version
ID:	1980828   Click image for larger version
ID:	1980829   Click image for larger version
ID:	1980830   Click image for larger version
ID:	1980831   Click image for larger version
Old 04-25-2014, 09:56 PM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If anyone was wondering, yes the thread is still going and yes the build is still going.
I have now completely planked the hull. I have also shaped the bow piece ($160 and a dremel later). i have decided against creating a balsa laminate before I glass the hull. Some sanding has started, I feel this is going to be a long process to a) fair the hull and b) get rid of the glue spillages.
Progress on the project is has been slow of late due to starting a new job, but finding time here and there to continue on with the project I started.
I have also been thinking about the design of my canting keel mechanism. My current plan is to cut some aluminium tubing to go over the top of the keel and then have another in the hull and pack the mechanism full of grease, to keep the water out. Will be sure to post some design drawings up before I construct this critical component.
Anyway here are some photos of the progress made.
Enjoy
ID:	1989998   Click image for larger version
ID:	1989999   Click image for larger version
ID:	1990000   Click image for larger version
ID:	1990001   Click image for larger version
ID:	1990002   Click image for larger version
Old 05-11-2015, 03:27 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been a while since I updated this thread. Overall progress so far:
  • 2 hulls made( first barely came off the building board in one piece due to using 1mm balsa and struggling to hold the desired shape, second one made with 2mm and then glassed).
  • deck beams cut and installed.
  • keel and canard mounting points designed and installed, and hopefully water tight!!!
  • redesigned and made extended spinnaker pole 50mm longer than specified, from carbon tube.
  • rudder stocks and servo mount constructed and installed.
  • currently working on yet another revision of my canting keel mechanism.
  • misc. parts ordered and delivered for running rigging.
plan from now to continue to get the keel mechanism working reliably and then move onto sheeting the deck and the installation of other radio equipment.
will upload photos in another post.
Old 05-11-2015, 03:36 AM
some_bloke02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Photos below
ID:	2095299   Click image for larger version
ID:	2095300   Click image for larger version
ID:	2095301   Click image for larger version
ID:	2095302   Click image for larger version
ID:	2095303   Click image for larger version
ID:	2095304   Click image for larger version
Contact Us Archive Advertising Cookie Policy
