Sail set up suggestions
[h=2]Sail set up suggestions[/h]
Can someone advise me of the proper sail setup. Does this look correct? Did not connect to electronics as yet. Pic on the manual looks similar. Including the manual cover pic and boat as is pics. Thanks Ron
Set up:main pointing at corner of transom & jib at shrouds, or just inside, when close hauled( sails fully in ).
Winch or sail-arm servo must be installed, working, and in correct position first.
fine tuning comes after bottom wet!
