ETNZ build please help!
Hi, I a newbie in sailboats & i am about half way done, having trouble with the sail setup. I need some coaching here[]
In the instructions it says:
1- Apply PVC strips on the sail in the position as illustration.
OK but apply with WHAT? glue? which glue? it doesn't say...
2- While trying to press the little 2x14 mm stainless pin in the Head Crane it "jumped" on the floor never to be found again[:@]
What can I replace it with? a little stub of a 2mm Carbon Fibre rod? will it hold?
Thanks for helping,
Vasek
Thanks for helping,
Vasek
CA
RE: ETNZ build please help!
Have you been to rcgroups sailboat forum? There is a lot of sailboat forum activity and quite a bit of info on the ETNZ. Do a forum search for the ETNZ and you will find a wealth of info and some good upgrade ideas. Stevo
BC, CANADA
Here is the link to the RCGroups sail forum and a couple of others that are full of excellent advice.
http://www.rcgroups.com/sailboats-59/
http://www.rcsailing.net/forum1/index.php
http://www.rcsailtalk.com/index.php
