New in construction
<span id="result_box" lang="en" class="long_text"><span title="" yc="Hello everyone," xc="Bonjour à tous," closure_uid_n7yw9a="53">Hello everyone,
</span><span title="" yc="I dream of seeing the videos and pictures of RC multihulls but as I've never done building I need your advice." xc="Je rêve en voyant les vidéos et photos de multicoques RC mais comme je n'ai jamais fait de construction j'aurais besoin de vos conseil." closure_uid_n7yw9a="54">I dream of seeing the videos and pictures of RC multihulls but as I've never done building I need your advice. </span><span title="" yc="- Would it be better for me to buy a used multihulls? Knowing that I live in Quebec and here there is not really so should I buy a European vendor despite cost " xc="- Serait-il mieux pour moi d'acheter un multicoques usagé?Sachant que j'habite au Québec et que par ici il n'y en a pas vraiment donc il faudrait que je l'achête d'un vendeur européen malgré les frais de" closure_uid_n7yw9a="55">- Would it be better for me to buy a used multihulls? Knowing that I live in Quebec and here there is not really so should I buy a European vendorknowing that thetransport cost</span><span title="" yc="transport (I do not know what would be the same transportation cost)." xc="transport (j'ignore même quel serait le coût du transport)." closure_uid_n7yw9a="56">should beexpensive(I do not know what would be the transportation cost). </span><span title="" yc="- Or build one myself knowing that I could make several errors (especially with the use of glass fiber / epoxy / carbon)." xc="- Ou encore en construire un moi-même sachant que je risque de faire plusieurs erreur (surtout avec l'utilisation de fibre de verre/epoxy/carbone)." closure_uid_n7yw9a="57">- Or build one myself knowing that I could make several errors (especially with the use of glass fiber / epoxy / carbon). </span><span title="" yc="Thank you" xc="Merci" closure_uid_n7yw9a="58">Thank you Eiffel</span></span> |
RE: New in construction
Hi Eiffel have you "built" any R/C sailboats before? If you have already done any with installing radio and mechanical eqipment, then you've already done the hard part in the past. Building hulls froma scratch and then glassing them scares most people awa\y, but it's actually easy to do.
ORIGINAL: Eiffel <span id=''result_box'' lang=''en'' class=''long_text''><span title='''' yc=''Hello everyone,'' xc=''Bonjour Ã* tous,'' closure_uid_n7yw9a=''53''>Hello everyone, </span><span title='''' yc=''I dream of seeing the videos and pictures of RC multihulls but as I've never done building I need your advice.'' xc=''Je rêve en voyant les vidéos et photos de multicoques RC mais comme je n'ai jamais fait de construction j'aurais besoin de vos conseil.'' closure_uid_n7yw9a=''54''>I dream of seeing the videos and pictures of RC multihulls but as I've never done building I need your advice. </span><span title='''' yc=''- Would it be better for me to buy a used multihulls? Knowing that I live in Quebec and here there is not really so should I buy a European vendor despite cost '' xc=''- Serait-il mieux pour moi d'acheter un multicoques usagé?Sachant que j'habite au Québec et que par ici il n'y en a pas vraiment donc il faudrait que je l'achête d'un vendeur européen malgré les frais de'' closure_uid_n7yw9a=''55''>- Would it be better for me to buy a used multihulls? Knowing that I live in Quebec and here there is not really so should I buy a European vendor knowing that the transport cost </span><span title='''' yc=''transport (I do not know what would be the same transportation cost).'' xc=''transport (j'ignore même quel serait le coût du transport).'' closure_uid_n7yw9a=''56''>should be expensive (I do not know what would be the transportation cost). </span><span title='''' yc=''- Or build one myself knowing that I could make several errors (especially with the use of glass fiber / epoxy / carbon).'' xc=''- Ou encore en construire un moi-même sachant que je risque de faire plusieurs erreur (surtout avec l'utilisation de fibre de verre/epoxy/carbone).'' closure_uid_n7yw9a=''57''>- Or build one myself knowing that I could make several errors (especially with the use of glass fiber / epoxy / carbon). </span><span title='''' yc=''Thank you'' xc=''Merci'' closure_uid_n7yw9a=''58''>Thank you Eiffel</span></span> He´s from Canada, has three ready-to-sail Mini40 trimarans - and might be willing to sell one of them to you. And if not, then he is still the one with the most practical experience in your area. Good luck for that and please keep us informed how it turned out. Idealist |
