Foiling Mini40 Tri - My FireDragon Foiling
Hi all,
there was sufficient wind, so I decided to do my first foiling tests with the v-foils attached - flying is fun [youtube]http://www.youtube.com/watch?v=cEHH6C26Eas[/youtube] Cheers Roland |
RE: Foiling Mini40 Tri - My FireDragon Foiling
Here is the latest clip with even more foiling action
[youtube]http://www.youtube.com/watch?v=hBsA9ieYj50[/youtube] Cheers Roland |
Roland,
cool foiling action! congrats to a well designed foil assist mini40. can you share some details on the foils? what is the weight position? How much from the aft (or front) is the foils mounted? Is this video with sym or asym foils? What is the length of the profile, what the thickness? 10% or less? What is the length of the foil itself?28cm or longer? What angle from waterline are the foils mounted? I am asking all these details as I am also trying to find a good foiling setup and I find it extremely difficult to find a good generic setup that would also fit for regatta (round course) scenarios. Many thanks for sharing any details. Eric |
ORIGINAL: egi1610 Roland, cool foiling action! congrats to a well designed foil assist mini40. can you share some details on the foils? what is the weight position? How much from the aft (or front) is the foils mounted? Is this video with sym or asym foils? What is the length of the profile, what the thickness? 10% or less? What is the length of the foil itself?28cm or longer? What angle from waterline are the foils mounted? I am asking all these details as I am also trying to find a good foiling setup and I find it extremely difficult to find a good generic setup that would also fit for regatta (round course) scenarios. Many thanks for sharing any details. Eric I'm using an asymmetric foils, the foils can be obtained from rcsails.com . [youtube]http://www.youtube.com/watch?v=aE_tARZoJGE[/youtube] [youtube]http://www.youtube.com/watch?v=LBdyGBWKu0A[/youtube] [youtube]http://www.youtube.com/watch?v=eDM85FYv04w[/youtube] Cheers Roland |
6th European Multihull Open - 29.6-1.7.2012 !
www.mini40.eu 29.6-1.7.2012 The 6. European Open for RC-Multihulls of the Mini40- and 2m-classes! |
1 Attachment(s)
<![if gte mso 9]><xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:DoNotOptimizeForBrowser /></w:WordDocument></xml><![endif]><span style="font-size:12.0pt;font-family:"Times New Roman";mso-fareast-font-family:"Times New Roman";mso-ansi-language:EN-US;mso-fareast-language:EN-US;mso-bidi-language:AR-SA">I could really use some help build that type of foil. I tried ten years ago and was not very successful. Mine had a float out front the sensed the water level and adjusted the foil angle.<span style="mso-spacerun: yes"> </span>Any hints? Thanks Gerald - http://rcspeedsailing.com/index.html</span>
The setup is very simple - I use fixed V-foils on my boat. No need to actuate while sailing, just a one time setting of the angle of attack (around 1 to 3 deg).
Hope this helped you. Cheers Roland |
[QUOTE=Multihull;11504955]The setup is very simple - I use fixed V-foils on my boat. No need to actuate while sailing, just a one time setting of the angle of attack (around 1 to 3 deg).
Hope this helped Cheers Hey Roland ! can you help me , I,m looking for wher I can bye a trimaran in Thailand ?? maybe a nightmare or shinobi , I tried to opend the page to rcsail but it dosent work Roland[/QUO so I was hoping you mait be able to help me , cheers Bjorn. |
