A123 batteries fo a sailboat?
Hi, I'm new to sailboats.
I have a little lake around the corner where I live so I want to go sailing on a moment notice. The recommended battery for my ENTZ is a standard 4.8V NiMH 3600mAh battery pack. The problem with that is that; 1) they don't hold peak charge for long if charged in advance 2) takes a long time to charge A123 batteries charge in 15 min thus my question. Does anyone use these in a sailboat? |
RE: A123 batteries fo a sailboat?
<span style="font-family: arial; ">
The recommended battery for my ENTZ is a standard 4.8VNiMH3600mAhbattery pack. The problem with that is that; 1) they don't hold peak charge for long if charged in advance |
It could be that your servos are drawing a lot of current.
I run my boats with a 6 volt NIMH 1400mAH battery pack. My average sailing time is around 2.5 hrs. every Saturday. After sailing I still have 5.0 volts. When I get home I charge the batteries over night. and I ready to go again. |
I have been using A123 batteries for 6 months now and get a full days racing 9am till 4;30pm, I prefer them over lipos because of the whole fire thing
I have used A123 packs in two different IOMs for a couple of years. No problems whatsoever. I just upgraded my Hitech arm winch to their newer version that is now rated to 7.2V. Perfect timing!
I do use a Castle Creations voltage regulator (CCBEC) to knock the voltage down to the rudder servo. The RX can handle a 2 cell A123 pack, but I usually put it behind the regulator too. I have the regulator set to 6V, BTW. I also use a 5 cell MiMH pack in my smaller Victoria. A123 is too big to fit, and the NiMH is plenty for that setup. They do lose charge over time, so it is best to charge them the night before you sail. My 1650 Mah pack will last most of a day. I usually swap them mid day if I am sailing a regatta, just to eliminate any possible problem there. I'd rather swap when I have time to, than have to swap when I have no time! |
Great! I might try the unregulated A123 then, since a freshly charged 5cell NIMH has (i think) more V than a A123 off the charger.
One more question, how do you guys waterproof the pack in the boat? Thanks for the help, V. |
I saved the plastic box that my Hitech servo came in. I cut a small hole in the top for the power leads to exit. The 2 cell A123 fits nicely inside and will keep any water in the bilge from splashing into the batteries. I have a rectangular hatch that is large enough to slip the box through, into a cradle to keep it from sliding around. The hatch is taped to seal it.
I sprayed mine with lots of clear spray paint works very well, just make sure you get it in all the tight spaces.
Oh without a doubt i get itin all the tight spaces!
Make sure there's not any sand or dust in those tight spaces, or things could turn ugly real fast!
lube it!</p> |
